Scored a new tow rig....
Re: Scored a new tow rig....
I like it!
Make sure that you check ALL of the fluids on that! The person I bought my Blazer off of said they replaced the brakes, trans fluid, you name it. I ended up spending almost a month replacing engine, transmission and brake fluids along with all of the brake components.
IndyG3- G3GM Enthusiast
- Street Cred: 11
Ohh I've already changed the fluid in the rear end, replaced the axle seals, checked the transmission fluid, transmission is so clean you can eat off of it and ther eis a metal tag on the top of the bellhouseing, I've replaced all the ball joints,m Idler arm, Got a pitman arm for it, changed the oil and filter and flushed the radiator and refilled with new dexcool. And put two good used tires on the rear where he had the wrong size on 2 rims. also claned and rebuilt the from calipers and installed new brake pads in the front, alt is new , I can see that and the starter is new I can see that. cleaned and adjusted the rear brakes. Its been a busy week.
Jim_Rockford- G3GM Member
- Street Cred: 4
nice! looks to be in great condition for the year/model
- Street Cred: 8
Similar topics» Yay the Knicks-Lakers game where Allan Houston scored 53 on Kobe and the Lakers
» Which Premiership player has scored the most goals in a season?
» The greatest goal ever scored at Old Trafford.
» Hutton has scored more goals than Defoe, Crouch and Keane combined.
» Every free kick that David Beckham has scored...
» ~~Introduce Yourself~~
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
