X pipe
+4
8 posters
X pipe
when i put the new engine in the malibu, ill probably go with the custom exhaust too. oldtimers dont have to pass emission control tests over here, so its going to be a straight pipe without cat or mufflers (havent really decided on that yet, but im pretty sure). id like to put a X pipe under there too. where is the best place to do that? i was thinking behind the tranny crossmember, but im not sure if that aint too far from the headers. does anyone have any pictures of that, or maybe any advice?
thanks
thanks
abajc3- G3GM Member
Re: X pipe
74MonteCarlo wrote:Mine has an H pipe.
that is one of the options for me as well, but i read in the john ligenfelters book that x-pipe is somehow better. i still have a couple of months to decide, so ill do some more research. im guessing that lambda sensor should go behind x or h pipe, especially after i put a dual plane intake on it.
ill ask another question in this thread as i dont want to litter the forum with a bunch of new threads: can i fit 6" olds connecting rods into a 305 and if yes, how much would that boost compression.
i really should be studying for exams instead of thinking about the car, but it aint as simple as it sounds...
abajc3- G3GM Member
Re: X pipe
What crank are you gonna be using?
BlackChevelleSS- Management
Re: X pipe
my pipes are bent together right at the tranny mount. looks like the cut the inner side of the pipe off and welded the 2 together. sounds good too
1973montec- Donating Member
Re: X pipe
BlackChevelleSS wrote:What crank are you gonna be using?
a stock one. new one is just too expensive for my current budget
abajc3- G3GM Member
Re: X pipe
no you cant unless you get custom pistons and im not sure about the big end of the rod
Re: X pipe
hmm, too bad. i found a set for 50$ on ebay, if anyone needs them i can post a link. custom pistons would be too expensive.
i just need 3 stock rods for the 305, the previous owner sold them separately and thought that if i get the whole set i wont need to find ones that match the originals.
abajc3- G3GM Member
Re: X pipe
BlackChevelleSS wrote:no you cant unless you get custom pistons and im not sure about the big end of the rod
It can be done & Dave Vizard shows how to do it in one of his books. I remember reading it on a budget 406 build that he did. I'll have to look for specifics though.
Re: X pipe
i have it right here Rago and its using the Olds diesel 6" rods ....
Re: X pipe
yes sir I am hurting my head by readin so much ..... But Limeyfive needs input much input LMAO
Re: X pipe
My system is stainless, and I don't know if anyone has a stainless X pipe. Haven't looked too hard yet. Summit may have one like that.
Re: X pipe
one word PYPES
Have a X pipe kit in garage from them 409 stainless but they have aircraft stainless available
get it thru BSMexhaust tell them Limey sent ya from Gbodyforums save some money on shipping
Re: X pipe
pila wrote:Thanks for that Limey. I'll check it out.
http://www.bsmexhaust.com/catalog/searchResults.php?cat_id=9
Re: X pipe
Yeah, looked on their site. Looks like what I could use. I'll have to measure how much room I have for the mufflers, behind the X pipe assembly.
Today at 6:13 by bracketchev1221
Yesterday at 10:52 by Joe73
Wed 24 Apr 2024 - 20:37 by 76 Malibu
Wed 24 Apr 2024 - 4:18 by relic7680
Sun 21 Apr 2024 - 21:32 by Limey SE
Sun 21 Apr 2024 - 21:26 by Limey SE
Fri 19 Apr 2024 - 13:46 by 73 ss wgn
Sun 7 Apr 2024 - 12:32 by Limey SE
Wed 27 Mar 2024 - 18:25 by 77camino
Tue 26 Mar 2024 - 15:35 by Whisperer
