Key Stuck In Ignition
So I got home from work last night to find that my key was stuck in the ignition with the car running, killed the power from under the hood to shut it off. Pulled the steering wheel off today before work, got down into the column pretty far, I'm at the point where you remove the lock cylinder, but there are a bunch of broken pieces in there and I can't get the damn thing out. Any ideas for fixing this? or should I just break down and go get a whole new column?
- Street Cred: 6
Re: Key Stuck In Ignition
You can just pick away at getting the broken stuff out of it, because you can always get a different one. I see that The Parts Place had rebuilt columns. Don't know if they were on an exchange basis....
pila- 2012 Donating Member
- Street Cred: 17
thanks pila ill check that place out, my girlfriends dad has an extra column but its non tilt and we dont know if its the right length or not (i think its out of a 68-72 chevelle or 70-72 monte carlo) so i think we may try to make that work, but ill check out The Parts Place.
- Street Cred: 6
Can you put up some pics of what you are seeing? You might be able to use some parts out of the older column, but not many due to the tilt/non tilt difference.
As far as swapping it with yours, it can physically fit, but the levers at the engine bay end are different
bigredlaguna- G3GM Enthusiast
- Street Cred: 31
I have one from Limey you can have NO Ignition Key in there and is NON tilt but till you can find a tilt column your welcome to it
pay for ship its yours........Oh and you will need the plugs from your column to make it work I had to rob them for the Cutlass Column ( floor shyt) I put in Limey
- Street Cred: 60
bigredlaguna wrote:Can you put up some pics of what you are seeing? You might be able to use some parts out of the older column, but not many due to the tilt/non tilt difference.
ill go snap a couple shots right now and post them. i appreciate the help.
- Street Cred: 6
Limey wrote:I have one from Limey you can have NO Ignition Key in there and is NON tilt but till you can find a tilt column your welcome to it
i would appreciate that a lot anthony thanks man
- Street Cred: 6
NO Problem travis It is a coulmn shift non tilt just to put your wires in from the El Co and install the new ignition lock and your good
- Street Cred: 60
hey guys thanks for the help (especially anthony) i didnt think id be able to get the lock cylinder out but i removed it from the car and took it to work with me and the Master Tech and I were able to figure it out, there was one circular piece that attaches to the lock cylinder that had broken off and jammed everything, i put the new one in without it and i think its gonna work fine. not sure what exactly that piece was for, but oh well, kinda glad this happened, now that the steering wheel is off im finally gonna put my grant mahogany one on.
- Street Cred: 6
If it was a plastic piece that was at the end of the cylinder, it is part of the steering wheel lock mechanism.
- Street Cred: 31
bigredlaguna wrote:If it was a plastic piece that was at the end of the cylinder, it is part of the steering wheel lock mechanism.
it appears to be made out of some kind of metal, ill have to take a pic of it
- Street Cred: 6
Similar topics» Stuck....and loosing will power!!
» cruiser80 '57 electronic ignition
» Megajolt Programmable Ignition Controller
» Key Stuck In Ignition
» Lock jamed solid
» Lock jamed solid
» 73 CHEVELLE SS PICS
» 75 cutlass
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
