Can't Find Oil Leak!
Post by mrimax on Mon Oct 03, 2011 6:05 pm
Hey all,
Anyone have any experience with a leaking oil filter assembly housing? My 1973 Grand Prix 400 Engine is leaking bad........
I changed the oil last week, and since then it has continually leaked but only when running. I changed the valve cover gaskets, the Oil Sending Unit, and replaced the shitty Fram to a Wix but still I have oil leaking down onto the oil filter and running down the side. I'm at my wits end, I cannot find where it is leaking from, any thoughts?
Thanks
Last edited by mrimax on Mon Oct 03, 2011 6:06 pm; edited 1 time in total (Reason for editing : add)
mrimax
Street Cred: 0
View user profile
Re: Can't Find Oil Leak!
Post by bigredlaguna on Mon Oct 03, 2011 7:19 pm
In this pic, it looks like the filter adapter is a separate piece. I would replace the gasket between the adapter and the block.
Street Cred: 31
View user profile
Post by Checyxtc on Mon Oct 03, 2011 8:52 pm
I had a similar problem with my 454 and here's what it boiled down too for me, hope it helps:
1st leak was from the plug in the block above the oil filter that my oil pressure gauge was plugged into (crappy brass fitting). The 2nd leak was from a bad rubber gasket/bushing in my z-bar which also screws into the block above the oil filter.
That was my experience with an oil leak in the same area for what it's worth...good luck M8.
Checyxtc
Street Cred: 2
View user profile
Post by Ghost Rider on Wed Oct 05, 2011 12:45 pm
I have to ask. Are you sure the old rubber gasket came off with the old filter?
Ghost Rider
2012 Donating Member
Street Cred: 3
View user profile
Post by mrimax on Wed Oct 05, 2011 4:10 pm
Replaced filter twice, have had it off 3 times trying to see if the old one was there but it seems like it's gone. Tried Barrs Leak Stop and it seems to have worked. Will get under it this weekend to try and find it, trying to get the vinyl top off right now.....
mrimax
Street Cred: 0
View user profile
Post by 77mali on Wed Oct 05, 2011 4:42 pm
I would try to clean the engine off at least near where your problem is with either steam or a degreaser.
Street Cred: 14
View user profile
Post by Ghost Rider on Thu Oct 06, 2011 5:35 am
If all else fails you could put dye in it after you clean it. That would mark it for sure.
Ghost Rider
Street Cred: 3
View user profile
Post by mrimax on Tue Oct 25, 2011 11:17 pm
Finally, found the culprit. The Oil Sensor was not fully tightened properly and since it was tightened this weekend, not a drop has spilled out. About time something was easy!!!!!!
mrimax
Street Cred: 0
View user profile
Post by 77mali on Wed Oct 26, 2011 5:01 am
Well that's good. Glad it wasn't anything else.
Street Cred: 14
View user profile
