Oil Pressure Help
Page 1 of 2 • Share •
Oil Pressure Help
Engine is blowing oil right through both valve cover vents. Running about 60psi @ 2000 rpm. Buddy told me to run a catch can system. Anybody used one before and if so where do I get one. News to me.
Ghost Rider- 2012 Donating Member
- Street Cred: 3
Re: Oil Pressure Help
catch can would help ya then here is some designed for the vettes but you could adapt to yours I guess as well
http://www.eliteengineeringusa.com/Catch_Can.html
- Street Cred: 60
What are the specs on the motor? Typically unless your pushing a motor hard, just use a pcv valve on one side and a breather on the other. It will take away the crankcase pressure. What kind of cylinder pressure are you getting when you crank it around?
I have run the recovery tanks, Trick breathers, and the header evac systems. But lets get some more specs first before advising anything.
prostreet75- G3GM Member
- Street Cred: 0
@ Prostreet how well do them header Evac work ?
- Street Cred: 60
prostreet75 wrote:What are the specs on the motor? Typically unless your pushing a motor hard, just use a pcv valve on one side and a breather on the other. It will take away the crankcase pressure. What kind of cylinder pressure are you getting when you crank it around?
Blueprinted and balanced 350. Mild RV cam and lifters. High velocity oil pump.
- Street Cred: 3
There don't work for the street, but they are not to bad for track cars. They don't really start to draw until you are buzzing the motor. And you have to position the bung and insert correctly in the header or it won't draw period. They are really more of a pain in my opinion. For the race applications I build, I usually use taller, more baffled breathers or the tanks. For street drivers you really don't need much more than a PCV valve and an additional breather.
- Street Cred: 0
what about if see's more time to the track then it sees street
- Street Cred: 60
Ghost Rider wrote:prostreet75 wrote:What are the specs on the motor? Typically unless your pushing a motor hard, just use a pcv valve on one side and a breather on the other. It will take away the crankcase pressure. What kind of cylinder pressure are you getting when you crank it around?
You shouldn't need much then. I'm surprised that its pushing any oil. Are you running a pcv valve? If not it might be the quickest / cheapest fix. If you don't want to use one, the tank should work ok. I'd still check the cylinder pressure when cranking, it shouldn't blow oil just cruising around.
- Street Cred: 0
Limey wrote:what about if see's more time to the track then it sees street
It will work. Just my personal opinion, I like to use the tanks, and better breathers. On the current motor in my chevelle, I used a pcv valve and a breather until I added the NOS. Then I got rid of the PCV and just added another Breather. Works fine and no oil. On a nova I built, I used the header evac system. It was a drag car with a 468 cu 11.1 motor with a 300 shot of NOS. Worked fine when racing, but at idle, it wants to push back instead of drawing out. On my boat motor, I'm pushing almost 900 hp and I use (2) 4" tall billet breathers that have 3 diverted baffles inside. No oil push.
- Street Cred: 0
prostreet75 wrote:Ghost Rider wrote:prostreet75 wrote:What are the specs on the motor? Typically unless your pushing a motor hard, just use a pcv valve on one side and a breather on the other. It will take away the crankcase pressure. What kind of cylinder pressure are you getting when you crank it around?
- Street Cred: 3
Maybe just need to keep my size 12 out of the gas some?
- Street Cred: 3
prostreet75 wrote:Limey wrote:what about if see's more time to the track then it sees street
So the two breathers should be just fine ?
- Street Cred: 60
Limey wrote:prostreet75 wrote:Limey wrote:what about if see's more time to the track then it sees street
Ya, should work fine! The only thing is, without the PCV valve, you might get more of an oil smell.
I used these on my car. Made by K&N
[img]
[/img]If I push it anymore, I'll will switch to one of these.
[img]
[/img]I use these on the boat.
[img]
- Street Cred: 0
Similar topics» Oil leak from oil pressure sensor wire hole
» MK1 Golf gti voltmeter, oil pressure, and temp pods
» Atomic-Moto: Klim Moab Pants and AXO Air Cage Pressure Suit
» Hiace Powervan Tyre Pressure
» tire pressure sensors
Page 1 of 2
» K5 Blazer
» 73 CHEVELLE SS PICS
» 75 cutlass
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
