4 row radiator conversion
Page 1 of 1 • Share •
Is there anything different between a 3 row and 4 row radiator to install one
billy-ray- G3GM Enthusiast
- Street Cred: 13
Re: 4 row radiator conversion
I think at the most you MIGHT need larger rubber rad mounts but I dont think so. I have a rad, which I believe is a 4 row, and it just bolted in. My rad was taken out of a 500 ci. caddy. I'd just measure the thickness of the end tank where the rubber sits and compare it to yours.
Joe73- G3GM Member
- Street Cred: 5
I had too use bigger rubber blocks and I even made a little bracket because I could not get it to sit nice and straight. It was a simple piece of flat 1 inch wide flat bar stock bent into sort of a half of a rectangle.I bolted it to the rad support and just let the radiator it self lean against it ,worked fine.
ant7377- G3GM Senior Member
- Street Cred: 12
i have a 4 row in my 73 mc. had no problems with it fittin.....
- Street Cred: 26
Ok cool so it should work but got to get it and see what I'm working with
- Street Cred: 13
Where are you getting yours from?billy-ray wrote:Ok cool so it should work but got to get it and see what I'm working with
Malicruiser- G3GM Member
- Street Cred: 6
I had a 4-row in a Chevelle years ago. It was heavy as hell too. I go with 3-row aluminum now, to save weight on the front end.
pila- 2012 Donating Member
- Street Cred: 17
I want durability not weight savings
- Street Cred: 13
I can't complain about durability in aluminum radiators, since my '92 pickup has one, 20 years old next May.
I suppose it depends on what part of the country, since salt is used on roads here (lots of it !)
- Street Cred: 17
My biggest concern is the aluminum cracking or warping Arizona heat is very unforgiving
- Street Cred: 13
What you have to worry about is that most aluminum radiators are glued together and some brands might come unglued. JB
- Street Cred: 21
Similar topics» Help on gls to gti conversion
» how-to b2200 to b2000 solid lifter conversion
» koyorad radiator utk kancil l2 manual
» grill guard and radiator shrouds
» Cara Pasang Fan di belakang Radiator yang dilengkapi sensor otomatis
» New New Yorker
» 76 S3 in Franklin Indiana
» Old Photo Tow Truck
» EGR
» 1974 Chevelle Malibu for Sale
» NO...NO...NO...
» '77 Malibu in Progress
» K5 Blazer
» 75 MALIBU CLASSIC FROM EL PASO TX
