Glove Box lock
Glove Box lock
I want to swap it out of my cracked glove box door and into my not cracked glove box door. How does it come out? Nothing in the service manual or body manual.
Re: Glove Box lock
http://thepontiactransampage.com/glovebox.html
It's not as easy as the page makes it look...LOL. Took me a few try's. There is also a nut on the back that you can remove & the whole assembly will come out, not just the cylinder. It's hard to get the right tool though because of the shape of the back of the lock assembly.
Re: Glove Box lock
You are like wealth of information ! I cant remember if the new one has a key though.
Re: Glove Box lock
A locksmith can prob cut one for you if you get a blank. Sometimes the good hardware stores have them. Ive seen a "plumbers" socket at Sears, they are usually large diameters and have cut outs & they're cheap. You may have to modify the opening a bit to fit around the cylinder holder. If I didn't get it out how the web site said, that would have been the next step.
Re: Glove Box lock
I did this last night .I used a very small "Precision" Screw driver to push in the tab and it worked fine. Thanks Paul !
Re: Glove Box lock
Anytime Anthony. Glad it worked out for you....did the tiny little slot guides fall out? I forgot to tell you about those.
Re: Glove Box lock
No nothing fell out and I had the key for the good cover so I was able to transfer over the original lock and use the original keys. I now know how a glove box lock works too.
Re: Glove Box lock
That's good info, I had no luck trying to figure that lock out...
Today at 19:29 by Limey SE
Today at 11:45 by lagunaman
Today at 11:25 by bracketchev1221
Thu 25 Apr 2024 - 10:52 by Joe73
Wed 24 Apr 2024 - 20:37 by 76 Malibu
Wed 24 Apr 2024 - 4:18 by relic7680
Sun 21 Apr 2024 - 21:32 by Limey SE
Sun 21 Apr 2024 - 21:26 by Limey SE
Fri 19 Apr 2024 - 13:46 by 73 ss wgn
Sun 7 Apr 2024 - 12:32 by Limey SE
