Chevy Rally wheel date codes
GM Rally Wheels
XA 14X5 BS-3 1/2 67 Chevy II with drum brakes
DA 14X5 BS-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with discs brakes
XB 14X6BS -4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 BS-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 BS-4 3/8 70 Chevelle Station Wagon
XG 14X6 BS-3 7/8 68-69 Camaro with discs brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 BS-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 BS-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 BS-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 BS-4 3/8 69 Chevelle SS Wheel
AO 14X7 BS-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 BS-4 1/16 67-68 Camaro Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 BS-3 1/2 68-70 Passen
Here are a few extra notes:
*BS-Backspacing
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
* All the hubcaps interchange with each other.
*BS-Backspacing
Re: Chevy Rally wheel date codes
I wish I had a dollar for every rally wheel I have gave or thrown away. JB
did you happen to find the codes for the "68" only 15x7 wheel?
First time posting not sure if this is in the right place..anyways whats the specs on the stock rally wheels on a 77 malibu classic coupe? And whats the max tire size I can fit on there?
mychev123- G3GM Member
Just refinishing a set I pulled off a '76 Monte Carlo some time ago and am sure they are the same as on your '77 Malibu. They are FW 15x7's. Backspace is 4 1/2". About 7" wide between the beads. Don't know how large of tire will fit. I'd be interested to know that, myself. Anyone?
they will fit the old schools G60 tires
What size should I get for front and back? Any and all suggestions please! I want it to have a muscle car stance & Really filled out wheel wells.
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire size comparer&sw1=255&ar1=50&bd1=17&rw1=8.0&et1=0&sw2=275&ar2=45&bd2=17&rw2=8.0&et2=0&text1=&text2=
Mcarlo77 wrote:Just refinishing a set I pulled off a '76 Monte Carlo some time ago and am sure they are the same as on your '77 Malibu. They are FW 15x7's. Backspace is 4 1/2". About 7" wide between the beads. Don't know how large of tire will fit. I'd be interested to know that, myself. Anyone?
Backspacing on the 15x7 Rally should be 4-1/4". Mine are the 77 Malibu ones. 255-60-15 tire is as big as I'd go on them.
Grand73am- G3GM Newbie
» Rally wheel question
» WTB 73-77 chevy Dark Buckskin OE steering wheel
» Lets make a play date............................
Today at 12:45 pm by Limey SE
Today at 11:44 am by mikidymac
Today at 11:34 am by mikidymac
Today at 10:48 am by 76Chevelle2Tone
Yesterday at 6:44 pm by Limey SE
Sun Apr 28, 2024 11:04 am by 454fourspeedss
Sat Apr 27, 2024 5:29 pm by Limey SE
Sat Apr 27, 2024 9:25 am by bracketchev1221
Wed Apr 24, 2024 6:37 pm by 76 Malibu
Wed Apr 24, 2024 2:18 am by relic7680
