what are you running?
rebel101150
okay guys i'm pretty curious before I do any upgrades. Whats your 0-60 times with what upgrades? i'm trying to push my car to 350 horsepower soon and i'm told it shouldn't be too difficult. what are you guys running?
rebel101150- G3GM Member
Re: what are you running?
Change carb. to at least a 600 or 650 cfm.(if your originally a 2 barrel) Use an aluminum intake, bolt on some headers, 2.5 in. pipes with good quality mufflers, change plugs plug wires and recurve the dizzy. For Starters! I run a high mileage 350 (stock bottom end), crane 272 cam, edelbrock performer rpm intake, ported and polished 2.02 /1.60 cast iron heads, and a Proform 750 cfm race style carb. Full MSD ignition. Hooker headers, 2.5 in. pipes with flowmasters. Never timed the car so I have no idea its 1/4 mile times. But it sure is fun, and not too bad on gas. Stock rear-end, I don't even know what size gears are in it. I broke my 4.11 posi shortly before I spun a bearing in the 454. Starting over with the 454.
Bruisr- G3GM Member
Bruisr wrote:Change carb. to at least a 600 or 650 cfm.(if your originally a 2 barrel) Use an aluminum intake, bolt on some headers, 2.5 in. pipes with good quality mufflers, change plugs plug wires and recurve the dizzy. For Starters! I run a high mileage 350 (stock bottom end), crane 272 cam, edelbrock performer rpm intake, ported and polished 2.02 /1.60 cast iron heads, and a Proform 750 cfm race style carb. Full MSD ignition. Hooker headers, 2.5 in. pipes with flowmasters. Never timed the car so I have no idea its 1/4 mile times. But it sure is fun, and not too bad on gas. Stock rear-end, I don't even know what size gears are in it. I broke my 4.11 posi shortly before I spun a bearing in the 454. Starting over with the 454.
she sounds like a beast
ZZ4 Crate engine. 355hp achievement unlocked
Is your engine stock? Or what motor are you starting with? As far as bolt on parts, you can get the biggest baddest parts out there, but its more about the right combination of parts to get max hp and tq.
JiMi_DRiX- G3GM Enthusiast
(Still in assembly)
Base:
SBC 350 w/ 4 bolt mains: 1988 Casting (bored to 356 ci; 4.04")
Stock Crank-@ 3.48 Stroke , w/ Flat top hypereutectic pistons
Edelbrock Vortec Aluminum intake w/ 4 BBL Rochester Q-Jet
Comp Cams RHS 23 degree Vortec Heads #12407 cast iron
(RHS went all Aluminum 6 months ago these are no longer avail)
Comp Cams XE 262 H Cam
Comp Cams Hydraulic lifters w/ High Energy push rods
Comp Cams Magnum rocker arms @ 1.52 ratio
Melling Select oil pump (+25% volume)
Standard SBC mechanical fuel pump
HEI Distributor (Stock type) w/ Heavy gauge plug wires & insulated boots
Champion race spark plugs # S57YC
Hooker Super-competition Headers
1-5/8” x 30” primary’s w/ 3” collectors
NO CATS
Mufflers T/B/D
Peak HP (on the Dyno) Comp Cams data:
Max Torque: 415 ft*lbs @ 3700 RPM
Max Power: 348 HP @ 5300 RPM
(350 ft lbs & 348 HP & 5300 RPM)
0-60 ?. We'll see next year.
Base:
NO CATS
Mufflers T/B/D
97 Vortec 350 w/performer rpm intake and a 600 cfm cam with an XE268 Comp Cam. Accel HEI Distro w/ super coil and stock delco iridium plugs.
Hooker 1 5/8 headers to 2.5 pipes with electric dumps before they exit thru flowmasters.
Here's a screen cap of the desktop dyno results for this build.
Kinda hard to see the results but 387 HP @ 5500rpm and 412 ft/lbs of torque @ 4000rpm
Well, at least thats what It's supposed to put out. I'll know in the spring once its all back together.
Biomedtech- G3GM Member
1976 Monte Carlo
350 horse Chevy 350
Turbo 350 trans w/ shift kit and Hughs 2500 converter
4-barrel Edelbrock 600 cfm carb
Edelbrock Performer intake
Aluminum radiator
OEM 3.73:1 gears w/ Eaton posi
Headers and dual 2.5-inch Tru-X exhaust
BF Goodrich 245/60-15 Radial T/A's
15x7 Rally wheels
1/4 Mile ET: 14.45 seconds @ 94.37 mph
0-60 MPH: 5.71 seconds
350 horse Chevy 350
Aluminum radiator
15x7 Rally wheels
chevy76monteman- G3GM Member
Today at 4:51 pm by 76Chevelle2Tone
