If its not one thing its another!!!
thepossumface
First time out this year came back and the rear main leaking bad. Anybody done one in the car before?? Don't want to pull the engine.
Tom77- Donating Member
Re: If its not one thing its another!!!
I have, twice over the years. Mine is a two piece seal. Here's how I did my two piece. Dont know which you have.
1. Remove distributor cap and lay it alongside the dizzy. No need to take the wires off.
2. Rotate engine to put your timing mark at 6 o'clock. That puts the cranks counterweights up in the block.
3. Remove the two engine mount through bolts. One on each side.
4. Grab a brick or a block of wood about the same thickness of a brick.
5. Put a floor jack, I like to use a smaller sized one, under the harmonic balancer and jack it up. Only need to get it high enough to put the brick or block of wood under the top lip of the engine side motor mount. Lay the brick or block on the frame and lower the engine. Now the motor is resting on the block.
6. Remove pan bolts and pan. Remember to get the right pan gasket set regarding the front timing chain pan seal. GM made a thick and a thin one.
7. Remove oil pump bolt and drop the pump. Good time to change the plastic collar that aligns the oil pump with its drive shaft. Moroso makes an all metal one.
8. Remove rear main cap and there's the seal. The new seal will come with a piece of plastic to guide the upper half into the block.
Do a google search for small block chevy rear main seal. There are some pics there as to where you should put some RTV. Very important to do that.
If you dont want to jack up under the harmonic then you could use an engine hoist or come along from above. But you'll have to remove the hood for that. Your only lifting the engine slightly so you could put the blocks on the frame and allow the engine part of the mount rest on them.
As for the 1 piece rear main seal, you will have to drop the tranny, flexplate/flywheel and get at it that way.
Good luck with it.
Good luck with it.
I just bit the bullet and pulled mine once , in and out and new seal in 2-3 hours. it makes life easier and you could clean it while its out, but if you dont have a cherry picker I could see why you dont wanna.
thepossumface- G3GM Member
Pulling the engine seems easier, if you have a cherry picker!
yeah true, check your local c.l for one I paid like 75 for a 3 ton one, and it does its work plus more, I use it for my mowers and cars.
But in the end its up to you
Ugh...sorry to hear that. All that work for a friggin gasket.
Thanks for the good information. Would like to keep engine in. Don't want to f--- with headers. Anyway to tell if its a one piece or two?
Here's a better link w/ pic that show the difference. Blocks & cranks are pretty specific to either application. I think some racing company's make an adapter if you need one but it might require to change the oil pan also.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=675984
http://craig.backfire.ca/pages/autos/boxchevy/350/crank-install
http://www.maxchevy.com/tech/2008/iii_5-409-3.html
You guys are frickin awesome! Hope I did the plus minus bar at the side right. Now the big question for all the marbles. Who wants to do it for me! Just kidding! Thanks again for all the information.
Ghost Rider wrote:LIMEY you are frickin awesome! Now the big question for all the marbles. When can you do it for me!
Bring a Old set of tires for the test session and would be MORE THAN Happy to do it for you !!!!
oh yea Fixed it for you LOL
I believe chevy changed to the one piece around 86 or 87. Thats about the time they also changed over to center bolt valve covers.
Jack that baby up under the harmonic and put a block under the motor mounts. You'll have the motor up real quick and easy then just unbolt the pan with an air ratchet and down she comes. Actually pretty easy and quick job. Just remember to torque everything when going back and definitely the RTV on the cap.
Not a bad job at all.
Ghost Rider wrote:You guys are frickin awesome! Hope I did the plus minus bar at the side right. Now the big question for all the marbles. Who wants to do it for me! Just kidding! Thanks again for all the information.
I wish some of us were a bit closer together so we could all line up our cars & problems therewith to fix & bang out all these nonsense issues like the A Team on Overhaulin.
I think im with you on that maybe one day when I hit the 40million lotto we can set up something like that for all of us Guna guys, but that is wishful thinking/77mali wrote:Ghost Rider wrote:You guys are frickin awesome! Hope I did the plus minus bar at the side right. Now the big question for all the marbles. Who wants to do it for me! Just kidding! Thanks again for all the information.
Limey SE wrote:Ghost Rider wrote:LIMEY you are frickin awesome! Now the big question for all the marbles. When can you do it for me!
I'll bring the tires and the liquid refreshment. You send me two cases of oil to get it there! LOL
Thanks to all the help from you guys it back together! Still dry for now. One think I have to know from Joe73 how in the heck did you figure out the 6 o'clock thing. You were dead on pan fell off with last bolt. Once again THANKS to all who commented. I used some of all the posts! If we ever all get together first round is on me!!!!
Glad you got it back together. I actually dont remember how I figured that 6 o'clock thing out. First time I did the job on my chevelle was in about 1985 or so. Just something that stuck in my head. Glad it worked out for you.
Good- now you can cruise & not leave a trail.
He's not leaving a trail! That's sweat from all that horsepower, that's what I used to tell people when my 454 leaked oil! LOL!!!
Bruisr- G3GM Member
