700R4
+4
IndyG3
Redsway76
8 posters
700R4
Anybody everr use a 700 R4 in these cars if so deos the current driveshaft work does it need shortned is there another factory driveshaft i can use ?
Redsway76- G3GM Member
Re: 700R4
Look for a 200-4R. Better gearing, lighter, cheaper, almost a direct swap. The only thing needed is to move the cross member back a little. At least that's how it is on earlier generations.
You can also beef them up to take some major power. Leave the 700-R4s to the truck guys.
Re: 700R4
There are advantages and disadantages between the 200 and the 700. Personally if it was me I would use the 700. Do more research until you know all sides of the question. JB http://www.chevytalk.org/fusionbb/showtopic.php?tid/147370/post/1059827/hl/700R4/fromsearch/1/#1059827
Re: 700R4
With the 700-R4, you may also run into firewall &/or floor pan clearance. My research is hands on experience with older A-bodies. Maybe the Gen 3s are different.
IMHO, the 1st gear in a 700 is too steep of a change to 2nd gear unless you have a wide power band... something to keep in mind.
Re: 700R4
i was gonna do this to limey but the drawbacks made me leave it a 350th....i may go to 4l60e later in life for dependability, didnt feel like cutting driveshaft moving the trans mount to a diff location was not worth it in my opinion
Re: 700R4
so from most of what im gatehring the cheapest and easiest to do would be the 200-r4 the only thing the 200 lacks is guts however it can be built hmm
im thinking i mihgt just stick with TH350 shift kit and New converter for now
Re: 700R4
200-4Rs were used behind Buick GNs & held up OK. If you want to get a beefier one, look for one from a mid 80's Monte Carlo SS or Buick GN. Otherwise buy one, get a billet servo & upgrade the input shaft. You should be good to go unless you plan on crazy horsepower.
Re: 700R4
It all depends on whether or not you want an overdrive or not. 2004r's are pretty much a bolt on job, since they are pretty much Turbo 350's with an overdrive thrown in. And it is possible to make either the 350 or the 700-R4 handle buttloads of power, and it all depends on where you look for one. Unless your building some kinda track monster, like Rago said, buying a 200-4R and putting a cuople things will make them more than plenty strong for a car.
IndyG3- G3GM Enthusiast
Re: 700R4
the 200 r4 costs more if you want to beat the snot out of it . 700r4 can with cheap little mods, plus there everywhere. but make sure you get the 4l60 its the mechanical version the 4l60e is electronic version of 700r4. personally i like a 4 speed manual or the th350
McCauley5983- G3GM Enthusiast
Re: 700R4
Your going to have to go to a drive shaft specialist..
Here is the link.. http://www.pstds.com/
Hydro King- G3GM Enthusiast
Re: 700R4
i put a 700r4 in my Monte- took me about 3 hours total.
the trans bolts right up to the stock motor, the stock crossmember bolts into the stock TH400 holes in the frame, cooler lines and column shift linkage bolted right up (but i can't get it down to L1).
the driveshaft needed to be cut about 3" shorter- i did mine on the floor of my garage using my trusty NAPA chain exhaust tubing cutter to cut the tube about 3" shorter, my air powered cutoff wheel to cut the remaining pipe off the yoke (cut the weld away and the yoke comes out of the tube), and my flat concrete floor to hold everything straight while i welded the yoke on. it's been together since August of 2004, and i've had the car up past 100mph with no funky vibrations of any sort.
was it worth it? maybe- in city driving, the deep first gear is nice to get the car going and the 1-2 rpm drop isn't too bad. for regular highway driving, the overdrive drops the rpms just a hair too low for my engine, which causes it to lug a little bit. i gained no mpg with the swap in regular driving. interstate driving is another story- at 75mph, the overdrive and lockup torque converter puts the motor right in a sweet spot where it doesn't lug and it gets slightly better mileage than the TH350 did.
novaderrik- G3GM Member
Re: 700R4
You did a great job of altering your driveshaft on your garage floor, but I agree with Hydro on that most people would never get it right and should be left to a good machine shop. There is nothing as bad as having a driveshaft that is not exactly perfect and if someone does it their self they better put a driveshaft safety loop on their car, like Hydro did. JB
