ideas for front springs
moneypit73
j
i put new springs in my buick 7 yrs ago. ordered for 73 350 buick springs from napa. put them in and, biong!! front end looks like a 4x4. still does today. havent settled at all! now ive the skinnys on the front, i really want the front end down. dont want to cut or heat, would like a used set to throw in there gotta be better than this!!
moneypit73- G3GM Member
Re: ideas for front springs
that will help with launch at the track LOL
BlackChevelleSS- Management
i have the 2" drop ones to bring mine down also the front looks like a 4x4 truck right now and the motor is in LOL, i think once i get the garage this weekend they will go in. and money i was browsing one of the other sites i am on and i seen a set of lowering springs when i find them i will post them.
yeah, look at my avatar!!i just want some used ones, kinda worn in.i got good shocks.
you can have mine if you want but i feel they will be the same for you unless you running the extra weight of big block
moneypit73 wrote:yeah, look at my avatar!!i just want some used ones, kinda worn in.i got good shocks.
Wow, I thought that was a pic of it launching!
it does transfer weight good! but it only settles down a couple of inches from that pic!! 4x4!!
we can put a dana 60 in the front with some 40 inch super swampers and go boggin' ...just like old times. ha ha... although you'll have to hang on, you wouldnt want your head to dent the roof, like it did some of my mud trucks !
j- G3GM Member
The springs on my 78 Elky have settled down to practically nothing. Every time I hit a good sized bump its like someone hitting you in the head. I would be glad to swap the rear ones to you if they would fit your front, but I doubt it would fit. I will be buying new ones pretty soon anyway. I have a lot of work to do to the rear end and will be taking it all the way out. It is rusted quite badly and I will have a heck of a time getting the control arms off. I may wind up cutting them off. They have been soaking in PB Blaster since last November. When I get around to taking them out I would just send them to you if you pay shipping. JB
put a big block in it!
im thinkin bout it!! gonna star pulling the 455 apart maybe next week to see what all is intailed. heads for sure need to be done,cam lifters. bottom end??????well see.
JB2, nope, rears wont fit in the front. not enough coil tension to them. good lookin out, though!!
Regardless what has been said on here ..........cutting a couple coils is perfectly fine!!
badbiscayne66- G3GM Member
thats why i offered him the fronts from mine( i am switching to a 2" lowering spring) if he didnt like the outcome he could put his back in
chop a coil or two out of the springs you have now. it's really the only way to get a stance that you consider to be "perfect"- even if you buy some fancy and spendy aftermarket dropped springs, they might also need to be chopped a little bit to make them "just right".
otherwise i'd say to get some 94-96 Impala springs. those cars used a suspension that was very similar to the 73-77 A body. should be able to find a complete set on ebay or Craigslist that someone took out in favor of dropped springs.
novaderrik- G3GM Member
Today at 7:18 pm by 76Chevelle2Tone
