Dash Questions
+4
8 posters
Dash Questions
I think I've read every article here about installing dash pads and decided that's not the option for me.
I've located a blue '75 non a/c dash, not sure what's all there as more pics haven't been sent yet, but wondering what do I need to be looking for?
I want to replace the cracked, POS I currently call a dash pad with this one if it's nice enough.
I know I can paint it, but would like suggestions on what product to use.
Are there any differences I need to be looking for?
The rest of my dash is fine except for the cut out for a digital clock in the clock face, just the pad on top is a mess, but figure if this is out of the car already it's more likely to get the complete treatment and be as close to perfect as I'm willing to go.
enjoy,.
Dino
enjoy,.
Dino
Dinomyte- Donating Member
Re: Dash Questions
As Dynchel mentioned, the only difference between A/C and non-A/C dash itself is the lack of air vents above the glove box area (non-A/C). Of course, the underdash vent ducts that run side to side will be missing on this non-A/C dash, but you can easily swap yours over if you have the A/C dash.
There is also the issue of the name badge above the glove box. '73 has the rectangular badge mounted on the surface of the dash and '74-'77 have the square badge that's indented into the dash.
As for painting, Wally (Wallyup) has posted some detailed info in the past on what prods to use and how to prep the surface. Check the archives or PM him. He's the master of interior work!
Re: Dash Questions
Thanks guys - I don't have a/c (forgot to mention that), and this is a non-a/c dash.
This means the only real question is what condition is the dash in.
thanks
thanks
Re: Dash Questions
If you paint a cap, there is a primer type stuff to use on it before painting. I have two caps that came out OK for me. They are not very difficult to install over the old dash.
This is my Malibu, and the Elco is identical. NPD has factory colors in paint for the vinyl.
Re: Dash Questions
Painting interior plastic pieces and our vinyl dashes is easier than ever. The products available are drastically better than 15 years ago. I do recommend SEM interior vinyl dye. However I'm not sure it's available in aerosol spray cans. I used this in my Laguna years ago and it held up extremely well. The products are so much better now that I think any interior dye will work great. However it's the prep work that's important. I know duplicolor has a good dye as well.
You want to thoroughly clean what you're going to dye. When you think it's clean enough... Clean it again. Want to remove as much of the silicones and waxes that have been applied over the years. Simple green works well for this then follow up with a wax and grease remover. Then when it's thoroughly dry, you can spray the color dye. Really light coats, don't lay it on thick.
Re: Dash Questions
SEM is available in rattle cans, I used landau black on my seats...looks OE.
Re: Dash Questions
Thanks again - SEM is what I've got. Any steps between cleaning and painting?
Re: Dash Questions
SEM sells a cleaner /conditioner you apply before painting.
Its called vinyl prep part # 38343
Last edited by dynchel on Sun May 25, 2014 5:03 pm; edited 1 time in total (Reason for editing : added details)
Re: Dash Questions
Just a good degreaser (wax and grease remover) then use that SEM pre cleaner, and scuff with a grey scotch pad, then wipe with a tack cloth and then paint!
Re: Dash Questions
Thanks guys - I'll let you know what comes of this, still waiting to get some pics before making the drive. Just want to know that the pad isn't all cracked up like mine is.
Re: Dash Questions
Wallyuph wrote:I have dealt with this problem for years. Bull dog is better then no adhesion promoter at all but still lifted in spots. I even have sprayed with regular PPG base coat and cleared the plastic with Auto clear and a flattening agent in it the clear and it was still popping up. I now use SEM all there products from start to finish. I get my products from my local Orielly’s auto store.
Check out the technical data sheet on this page for instruction I have touched on below.
http://semproducts.com/product-catalog/flexible-coatings/color-coat/
Here are the steps I use.
Handling and Application
PREPARATION: Vinyl:
1. Clean first with 39362 SEM SOAP and a gray scuff pad.
2. Rinse with water and dry. If contamination still exists, water will bead on the surface. Repeat
this step until beading no longer occurs.
3. Clean thoroughly with 38343 VINYL PREP using a clean lint free towel and wiping in one
direction.
4. Rinse with water and dry.
Plastic:
3. Clean with 38353 PLASTIC/LEATHER PREP.
4. To promote adhesion on ABS, PVC and other similar plastics, apply a medium wet coat of
38363 SAND FREE. COLOR COAT should be applied while 38363 is still wet. As the
38363 evaporates, the COLOR COAT is drawn into the surface creating excellent adhesion.
-ORTo promote adhesion on TPO, EPDM, PP and other similar thermoplastics, use 39863
PLASTIC ADHESION PROMOTER or 77723 XXX ADHESION PROMOTER.
TECH TIP: If the type of plastic is unknown, place a drop of acetone on the back of the plastic and rub
it with your finger. If the plastic smears and melts, use 38363 SAND FREE for your adhesion
promoter. If acetone does not have an affect on the plastic, use 39863 PLASTIC ADHESION
Then top coat with light coats of SEM Color of your choice.
39362 SEM SOAP
http://semproducts.com/product-catalog/prep-products/scuff-and-clean/
is specifically designed as a first step cleaner for all repair and refinishing procedures.
http://semproducts.com/product-catalog/specialty-products/xxx/xxx-adhesion-promoter/
PROMOTER
Re: Dash Questions
With that much information Wallyuph I think I can make it perfect. Now all I need is to get it . . .
Re: Dash Questions
Well I picked up the dash today.
It's not is nice as was promised.
Yes there is a speedometer and other gauges in the dash, everything's there except the glove box.
That's the damage on it. I'm wondering if anyone's got ideas for the single speaker in the middle, and the crack. Even in this state it's better looking than the dash pad I've got.
I figure there's at least all the vents, switches and the lens for the clock, and I can put my stereo in the dash rather than the glove box, not to mention other parts.
Re: Dash Questions
You can fill the hole with body filler sand it smooth prime that area and re drill the holes in it, then dye the whole thing, be barely visible, I would leave the cracks alone, they don't look too bad.
Re: Dash Questions
guys Guys doesn't anyone remember the Blue Collar Buick how to on Dash repair ??
http://www.spike.com/episodes/yijpgz/powerblock-muscle-car-blue-collar-buick-interior-and-payoff-season-4-ep-114#respond
Re: Dash Questions
Not enough padding on those dashes to really matter much. I still believe a dash cap is the way to go.
I believe the original idea of a padded dash was because it was softer then metal when someone's head hit it ! No seat belts when the padded stuff came along.....
Re: Dash Questions
Limey wrote:guys Guys doesn't anyone remember the Blue Collar Buick how to on Dash repair ??
I've watched the whole things twice but there is no mention of what the product on the dash is. Anybody know?
thanks,
Re: Dash Questions
yes, I just noticed they didn't list it at the bottom of the episodes like they used to.....
Re: Dash Questions
Here watch this and look at there other videos. On Dye/ paint here. http://www.semproducts.com/how-to-videos/
It looked like SEM paint to me from the side of the can.
I don't know if they showed what they used for texture as the video kept freezing up on me. After you fill the cracks and are read for paint I use Rock guard in a medium texture . I buy 3M 05911 and it matches the factory texture on the panels or dashes. You can paint over it with your color then.
Key is follow all the prep and adhesive promoters.
» DASH PAD AND DASH REMOVAL FOR 1973-1977 CHEVELLE, MONTE CARLO AND MOST OTHERS
» bumper questions
» SS wagon with 4speed
» bumper questions
