74 monte carlo down in south FL
+6
77cruiser
10 posters
G3GM :: G3 :: Introductions
hello guys im Brian Scarbs , of ft lauderdale FL
my car is a nice 74 monte carlo ( factory 2brl ) 350/350 with 273 open rear end.
car came to me in realley nice shape - but the factory 2brl setup was terrible
ended up eventually swaping on the edelbrock 2701 intake with edelbrock 600cfm manual choke carb
thought it would "wake up" the car a bit - sadly it did not - why ? the factory exaust manafolds had air tubes in them wich were terribly restrictive. after adding a set of patriot clipster headers with new 2.5" pipes the car was finaly fun to drive, but i want more fun so i added tci breakaway torque converter ( 1000 rpm over "stock" ) and a B&M shift kit stage 2 as well as the B&M quick silver shifter ( long time favorite shifter )
i figured the stage 2 on the kit would hit nice from first to second shift - but i believe my high stall and gearing in the rear axle are preventing that nice tire "bark" i was hoping for.
imediate plans for the car = 373 rear gears and posi unit / as well as get the tranny fine tuned im still thinking it does not shift and work exactly like i was thinking it would - it shifts from 1 to 2 pretty low still
cut a hole in the hood ( gasp ) and get goodmark steel cowl weld on fabbed on.
and slightly further away ( few more months ) install a hot 383 with a realley worked brodix single plain high rise
have a buddy who builds motors up in TN putting it together now, should be real nice power im exited.
brian74montecarlo- G3GM Newbie
Re: 74 monte carlo down in south FL
Welcome! Nice car ! I have a black 73 Monte as well as the one in my avatar. Having fun keeping that hood clean and dust free I bet.
Very nice. Never under estimate the gains you get from basic mods.....especially on a mid '70's car.
also have a secret sub ( high end tc sounds 12" audiophile grade )
its a sealed box in the trunk built to "play" firing in to the cabbin of the car so there is NO trunk rattles or any other annoying stuff usualy associated with subwoofers in trunks. its realley a strange design i came up with as the sides are all sealed off to the cabbin of the car so no sound preasure from the sub goes to the trunk - its all directed thru the back seat in to the cabbin of the car. the strange angle its at was because the trunk springs were totaly in the way
my plans are to hide some more mids up front and play it all from this old school fultron 6 channel amp it wont over power any of my speakers but should make for a nice normal stereo type setup
and im lucky enough to live near a marina so i get this rec fuel with no ethonoal
my car has never run better with this fuel. i hope my new engine being built can run it ( 10.5 to 1 compression i believe )
was going for an exaust tip style called "bell flower" but decided to use larger diamater tips than normal
its kinda cool in its own way - like having side pipes for behind your rear tires lol
i found the pix of my factory manafolds with the air tubes - look how far they went in - they were literly choking off my engine
Let me know how that ends up sounding for you with sub set up.
I have two 10" subs in a sealed box that is up tight and fastened to rear deck. its hard to see them in the photo below but they are under the metal mesh. I glued the metal mesh in to rear deck board with window urethane so it would not rattle. Then did fiberglass pitched cones for the speakers. tweeters are on side panels. It sounds great running two amps one for subs and one for components.
Didnt realize they went in that far! Maybe I should take mine off
i was told the air tubes can be "carefully" removed and you can replace the open hole on top with a threaded cap
but in all reality a set of headers / long or short are the way to go - so worth the performence and drivability over stock manafolds
If you take them out a simple.short bolt or a pipe plug will close the whole.easily. Ant, you wont feel the difference in the seat of your pants.
Welcome, and nice ride. . ..
Dinomyte- Donating Member
installed trans cooler today - un hooked from radiator entirely and run just to the cooler - size 11x8x1.5 - states 20,500 btu cooling capacity ?
its mounted where it gets good flow hope its enough... should be
daddys little helper haha
Did you mount the in on the bottom and.out on top ?
You should run it through the factory cooler first then through the external cooler. That is the same cooler I have, it must work as it gets very hot to the touch.
I think with this monte being a Florida car, I'd keep it flowing just through the auxillary cooler. No need to expose the tranny fluid to high engine coolant temp in the rad.
In the northern states then I'd run it through the rad first since we get colder temps.
Joe.Im not going through the trouble then.Joe73 wrote:If you take them out a simple.short bolt or a pipe plug will close the whole.easily. Ant, you wont feel the difference in the seat of your pants.
Joe73 wrote:Did you mount the in on the bottom and.out on top ?
how the factory lines were on the radiator - i took the upper line and mounted to the upper on the new cooler so it flows exactly like it used to just not thru the radiator anymore
and agreed that the radiator will have a hard enough time just cooling coolant in the south FL brutal sun and heat.
my plan is for a used aluminum c&r radiator from a dirt late model ( getting in trade for basicly free )
and about the air tubes
i promise you going from the factory manafolds with tubes to the patriot clipster headers it totaly woke my engine up.
simply swaping out the factory 2brl and carb to the edelbrock 2701 and 600cfm carb did basicly almost no improvment in performence until i put the headers on with real 2.5" duals all the way to the rear - ( had crush 2.25" duals on the car with factory manafolds with air tubes ) and the engine just couldnt exhale, so id imagine you might feel it in the seat of your pants if you run the engine up to or above 3k rpm. but if your just daily put put driving to the grocrey store then no need to mess with the air tubes.
strange side note - i thought i had an exhaust leak at the gasket from factory manafold to block - but it was one of the air tubes on the back side i could not see had a small pin hole rusted thru it - allowing exhaust leak that was tricking me thinking it was somewhere else. super annoying too = no matter what i couldnt figure out how to rid that leak.. was a pin hole i couldnt see in the exhaust tubing the whole time. just fyi incase any one else has the same strange exaust leak they cant find - it might be a hole in one of the air tubes...
