Original Dual exhaust System?
+15
carcass
v8power
19 posters
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
Hey Guyz
I like to have a Dual Exhaust Sytem for My 74 350 chevelle.
Anybody knows a good cheap Exhaust Kit look likes the Original exhaust system?
Where can i bought it?
I found two seller but i don't know the systems are original and works correctly on my car.
http://www.summitracing.com/parts/sum-680130
http://www.ebay.com/itm/1973-1974-CHEVELLE-MONTE-CARLO-DUAL-EXHAUST-ALUMINIZED-W-350-400-ENGINES-/181112227749?pt=Vintage_Car_Truck_Parts_Accessories&fits=Model%3AChevelle&hash=item2a2b2147a5&vxp=mtr
A other thing, they must be can send it international.
v8power- G3GM Member
Re: Original Dual exhaust System?
If you have a NAPA they have walker. They fit beautifully
1973montec- Donating Member
And if the price seems high at the NAPA you are in, try another NAPA store. The prices will vary greatly between franchises.
jerry46765- Donating Member
what do you thinks about my two links?
i think the item on ebay really interesting. He can send it to switzerland.
If you want original appearing, then Walker is it. The Ebay price is good, but you have all the part numbers in that picture. Take it to the largest NAPA in your area and get a price. You may get it for the same price without paying shipping.
If you want performance, the sky is the limit.
Switzerland, no Napa there. See what the guy on Ebay will charge to ship it to you.
x 3
The Walker system is the correct stock replacement.
I'm assuming you have the original exhaust manifolds bit if you have aftermarket headers, you'll have to modify the front of the exhaust to fit the collectors.
the shipping charges are not so high (225 dollars)
Is the ebay item a stock replacement?
I have the original headers with a single exhaust system.
If it's a single exhaust then the parts you have up there are incorrect unless you are converting to dual exhaust. They don't show a single exhaust for a 74 Malibu- which engine do you have?
If you have single exhaust then look at this one- it's for a 74 Monte Carlo but underneath it should be similar. (for 350 5.7L or 400 6.6L)
http://mastercatalog.walkerexhaust.com/english/ExhaustCouponLargeScreen.asp?img=10619
I have the K Code 350 Engine.
Yes i like to have dual exhaust. Actually i have the single system like the monte carlo you send in the link.
I think its the same engine like the Laguna S3.
Then the Ebay (Walker exhaust) link you have is correct & you're engine is going to breath a lot better with the duals.
Just make sure you have a double hump crossmember. My '74 came with one, but it would bee a good idea to make sure.
Very true. You can also notch the one you have if need be.
77mali wrote:Very true. You can also notch the one you have if need be.
I notched mine and worked great !!!
what it looked like during the notch
After the Notch
73 and 74 are all notched arent they? Does Walker still produce those parts? Are they still available? Anybody buy em recently?
They're on Walkers website Ant- Monte & Chevelle/Malibu anyway- maybe others as well.
Also when searching for '73 they are refereed to as Chevelles all other years are Malibu when searching on Walkers website. For 75 Malibu they even show the Cat w/ single exhaust.
73 and 74 ( MOST ) Are dual exhaust crossmembers 75 and up went to Cats on MOST cars and went to single exhaust on MOST this is what the dual exhaust looked like
On the '75 & later cars & Elcos, I usually find a '73 or '74 cross member. Not very easy to find these days though. The guy I bought my '75 Elco body from had one, so I was lucky on that one.
73/74 chevelle and monte with sbc.
front pipe left side 47441 walker
front pipe right side 46367 walker
Thank you guyz i order the exhaust system on ebay.
i
i
the guy from Geneva is really cool. my x-boss bought this setup from him for a 69 hurst olds.
and the 66 cutty vert and the 66 442 cutty (under cover)
1973montec wrote:73/74 chevelle and monte with sbc.
Are you sure these are good numbers? I contacted Walker and I was told they don't make the front pipes between the engine and muffler. I tried searching these numbers and have come up with nothing. If anyone has any idea where to get these it would be greatly appreciated. I also have the link to the ebay ad saved to favorites.
i have them in my hands as we speak. bought them from NAPA in 1995.
not the best pic,but i looked right at them for numbers.
Look on eBay, a guy in Geneva Ohio reproduces these and others.
» Dual Exhaust System for '75 el Camino
» Deep sounding muffler on a Double stock 2'' exhaust system?
» Jegs 2.5" dual exhaust kit for $114
Page 1 of 4
