steering shaft
+4
8 posters
Re: steering shaft
I installed my linkage and noticed I was missing the washer/bushing (GM 1377083) that goes on the frame by the spring.
This is the cheapest one I found at $1.18 shipped. I haven't installed it yet but looks like it will fit.
http://www.ebay.com/itm/281283833773?item=281283833773&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
(Not my linkage just showing location)
Hawk03- G3GM Enthusiast
Re: steering shaft
I'll have to look closer at mine, I knew I needed the obvious one above, but didn't really look closely at the bottom. For $1.18 I may just replace it for the h3ll of it.
Re: steering shaft
Interesting...I think mine was/is missing. Didn't even realize I needed it. +1 :-)
Re: steering shaft
It's a nylon sort of washer, which is flat on one side, and domed on the side that goes into the bracket on the frame. It should also have a flat washer on the flat side, so the spring doesn't dig into the nylon plastic.
If the linkage gets sloppy, the hole in the nylon washer may be worn oversize. I just replaced one on my partners pickup truck because it was worn oversize. Now he knows what gear he is in !
