Quarter Panel Compatibility
Hey guys,
I was wondering if these quarter panels (which are stated to fit the chevelle coupes) is the exact same as the ones on the sedans?
https://www.opgi.com/chevelle/1976/sheet-metal-body-panels/quarter-panels/1667100/
Thanks
Thanks
lars- G3GM Member
Re: Quarter Panel Compatibility
The only thing that would be the "exact same" is the wheel opening arch. The quarters listed, like you mentioned are for a coupe. If you had a rusty 4 door. You could use those quarters and cut out the entire wheel opening, and graft it in. You wouldn't get the "dog leg" close to the door.
Before any aftermarket panels were available and GM stuff was discontinued, there was a transition point where you had to work with what you had. I had a 75 4 door, needed quarters, no one made them, none to be found, no internet. So, what I did was found two good front fenders and grafted the wheel opening from the fender into the quarter. The fronts actually have more of a bulge, more pronounced flare. No MIG welder in the late 80's, they were expensive! All brazed with a torch.
That worked in my favor as to be able to fit bigger tires in the back for winter. More specifically BFG 33x12.5. It looked like a dragster from the back. The tire most definitely filled the well.
Thank you, As my wheel openings are fine, and all I wanted was the edges/door bits I guess this would be the wrong kit for me! That sounds like a hell of time. The four doors still don't get a lot of parts love, mostly just the two doors.
lars- G3GM Member
4 door quarter
there is a nos 4 door quarter on ebay , there was another left and right but a member on here already bought them
454fourspeedss- G3GM Member
» quarter panel fix?
» 73 El Camino quarter panel source?
