Upper control arm bump stops
Getting down to buying the final parts for the front end rebuild and needing bump stops for the upper control arms. Which ones work/fit and what don't? What did you guys find/buy for yours? Do ones for 70's model GM trucks work? Thanks
KC77Monte- G3GM Member
Re: Upper control arm bump stops
Just bought these from energy Suspension. Upper & lower for a '70/'81 Camaro are what you need
I bought red, but they available in black
KC, I found that the uppers your asking about were pretty much a pain to install for me. They were energy suspension. I fought with them for quite a while and used lots of lube on them. They finally went in. I dont recall the part number but if I remember correctly they also fit a camaro like dynchel stated.
Interesting, I lubed mine up with silicone paste, any pulled them though (the top) with plyers, went right in.Joe73 wrote:KC, I found that the uppers your asking about were pretty much a pain to install for me. They were energy suspension. I fought with them for quite a while and used lots of lube on them. They finally went in. I dont recall the part number but if I remember correctly they also fit a camaro like dynchel stated.
Thanks Guys. Found the part number for the camaro listed on the energy suspension site and found them at rockauto and placed the order.
Yep, that's all I put on all of the control arms I do. They hold up a helluvalot better than the rubber ones.
brownbomber77- G3GM Member
