17 inch tires?
+6
Zaptiah
NOMOREWORK
alowerlevel
10 posters
G3GM :: G3 Tech :: Wheel / Tire fitments
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 17 inch tires?
How do you like the 17" rallys ?? Wish was closer the Second SE needs some wheels the rims that were on have rust thru from being buried up to the two bottom bolts in the grass after 20 years of sitting in a field ( floors also LOL )
Re: 17 inch tires?
I really like the 17’s. They look even better in person. I probably need a little more sidewall and be 2”” lower all around. Someone before me must’ve put some taller or stiffer springs on it. My original ‘76 that I bought new never sat that high. Anyway , I feel like I made a good choice in wheels. Kinda period correct but custom at the same time
76LagunaS3- G3GM Member
Re: 17 inch tires?
Kewl I agree Lowering may Help will fit the look better I think just front drop springs should be good Back looks good I think
Re: 17 inch tires?
Thinking about 2” drop spindles in front. Would I have to change the springs too ??
Re: 17 inch tires?
I believe so BUT I havent done a drop with spindles just in past used lowering springs on front they were 2" Impala SS drop springs only lowered it around 1 and 3/8"
Re: 17 inch tires?
It is not necessary to change the springs with the 2" drop spindles. That was the premise , drop the car 2" and you still retain all the steering geometry. Basically , no re-alignment would be necessary.
But , if your running 40+ year old springs...change them.
Anyone can "chime" in if I'm off.......
impalamonte- G3GM Enthusiast
Re: 17 inch tires?
impalamonte wrote:It is not necessary to change the springs with the 2" drop spindles. That was the premise , drop the car 2" and you still retain all the steering geometry. Basically , no re-alignment would be necessary. Â
I'm with you -- as I understood it, the whole point of drop spindles was so that you could get a lower stance without changing springs.
Re: 17 inch tires?
That's the Only reason I was thinking new springs is the age of springs if never replaced I just assumed you would replace the tired springs as well
Page 2 of 2 • 1, 2
Page 2 of 2
Today at 2:22 pm by REVINKEVIN / Mr. 600+HP
Today at 12:56 pm by Limey SE
» Dash Solutions
Yesterday at 1:16 pm by 76Chevelle2Tone
» Window louvers
» 1973 Chevelle SS 1 Family
