Valve Seals
2 posters
Valve Seals
While I am doing some upgrades on my engine this year, I have decided to replace the valve stem seals on the heads. I am going to do the job without removing the heads. Does anyone have any recommendations on some decent valve stem seals for my '76 350? I am assuming I can get something better than what Chevy used in '76.
76 Malibu- G3GM Member
Re: Valve Seals
I would take a look at seal made from Viton. That stuff is excellent. I have a viton material rear main seal in my engine.
Re: Valve Seals
I am assuming that my car would have come equipped with just the o-ring style seals. I was thinking of going to an umbrella seal and the o-ring. I like the idea of Viton. Looking at Rock Auto, Fel-Pro lists both the o-ring and umbrella seals for my car, but I think they are just rubber.
Does anyone have a specific part number/brand that would work with stock 1976 350 heads?
Re: Valve Seals
I see some on summit from Manley. Notice the different valve diameters. Might need to make a call to Manley to confirm size. https://www.summitracing.com/search/part-type/engine-valve-stem-oil-seals/product-line/manley-viton-valve-stem-seals
https://www.jegs.com/p/COMP-Cams/Comp-Cams-Viton-Metal-Body-Valve-Stem-Seals/1122701/10002/-1
More should come up if you google viton valve seals.
Re: Valve Seals
Thanks for the links, but those are all positive stop seals. Correct me if I am wrong, but I thought the positive stops only work on factory heads after machining? That's why I thought my only options were umbrella seals or o-rings.
When I have more time, I will search around Summits website to see what I can find.
Yesterday at 7:12 pm by 76Chevelle2Tone
Yesterday at 1:56 pm by Limey SE
Thu Apr 25, 2024 10:52 am by Joe73
Wed Apr 24, 2024 8:37 pm by 76 Malibu
Wed Apr 24, 2024 4:18 am by relic7680
Sun Apr 21, 2024 9:32 pm by Limey SE
Sun Apr 21, 2024 9:26 pm by Limey SE
Fri Apr 19, 2024 1:46 pm by 73 ss wgn
Sun Apr 07, 2024 12:32 pm by Limey SE
Wed Mar 27, 2024 6:25 pm by 77camino
