Transmission gear selector linkage repair
2 posters
The gear selector linkage in my 1974 Monte Carlo had developed lots of slack over the last 48 years so this past April 23, 2022, I did something about it. This video shows what I did…
Enjoy and let me know if you have any questions.
zucchi- G3GM Member
Re: Transmission gear selector linkage repair
Maybe share the Replacement part numbers I for one have to do this is and Trans is out for Engine Upgrade ??
Limey SE wrote:Maybe share the Replacement part numbers…
You bet.
From the parts manual on gmpartswiki…
GP 4.040: 488452 – SHAFT, EQUALIZER CONTROL
GP 4.045: 9795470 – LEVER, PARK. LOCK AND RANGE SELECTOR OUTER {although I used 480565}
The swivel and it's components can be purchased together but their parts are…
GP 4.037: 1385607 – SWIVEL, CONTROL ROD LOWER
GP 4.037: 3989434 – WASHER
GP 4.037: 3989433 – SCREW
The spring, washer, bushing, clip kit includes…
10040797 – CLIP
492346 – WASHER
10236109 – SPRING
1377083 – BUSHING
The grommet was
GP 4.037: 1394293 – GROMMET ASSY
I got these parts from different sellers on evilBay
zucchi- G3GM Member
This is a follow-up to my original post.
After I replaced the worn transmission shift linkage parts, much of the loosy-goosy slack was taken up but there was still some noticeable and annoying looseness as can be seen in the original video at time 24:21 - 24:45. I suspected there was an issue with the selector and detent spring inside the transmission. I started documenting the repair after I dropped the pan and saw what you'll see in the video. Please note that I hadn't intended to record an "instructional" video so I didn't have a tripod, etc. The camera was hand-held and all the footage is "raw", i.e., unedited.
One thing I didn't mention in the video is when I dropped the pan and inspected everything, the nut on the inside of the transmission that holds the range selector lever (#330136) onto the selector shaft (#470107), didn't seem as tight as it should have been. After replacing the selector lever, when I tightened up the nut, I put the torque wrench on the nut on the outside of the shaft and a box wrench on the nut on theĀ inside so that both nuts would be properly torqued. I would expect this to prevent a repeat of this issue. Furthermore, I'll note to check the torque on those nuts whenever I do transmission service in the future.
As always, I hope this helps those with the same problem
zucchi- G3GM Member
Finn Monte likes this post
Today at 6:43 pm by 76Chevelle2Tone
Today at 12:50 pm by 76 Malibu
Today at 8:37 am by zucchi
» Window louvers
» 1973 Chevelle SS 1 Family
