AC compressor belt tension
Any of you guys have a good trick to get a good amount of tension on the AC belt? I've tried prying near the front of compressor between it and the big bracket bolted to the block but can't get it to go and the belt is flopping around. It's on my 73 Monte with 454. All stock stuff.
Re: AC compressor belt tension
The belt on my '74 Monte Carlo, small block flopps around a bit but there's no slipping. If it's not slipping or squealing then don't sweat it. If it is squealing, try some Gaskacinch.
Looking over the shop manual, I would start by loosening the two pivot bolts and the two adjustment bolts. If the compressor doesn't pivot all, you need figure out why. It should pivot easily after loosening those four bolts. You may need to unbolt it completely to fix that. After you've addressed that, pivot the compressor to increase belt tension and tighten the rear adjustment bolt first, then the front, then the pivot bolts.
zucchi- G3GM Member
Limey SE likes this post
I'm gonna give it a try like that. Tighten rear first. Thank you.
I bought a fan belt tensioner tool years ago for this reason because I just couldn't get the belt tight enough on my '67 Cougar. Only one like it I could find just now is this one...and, I'm certain I didn't pay anywhere near this much for mine. One of those tools that are seldom used but sure come in handy when you need it. You could wedge it between the a/c compressor body or pulley shaft and another nearby component and tighten it.
https://www.amazon.com/Supco-Belt-Tension-Jack/dp/B008FM8BM4/ref=asc_df_B008FM8BM4/?tag=hyprod-20&linkCode=df0&hvadid=242022160290&hvpos=&hvnetw=g&hvrand=2550720820194726733&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019555&hvtargid=pla-575152475703&psc=1
I had one years ago and I broke it. I'm gonna check harbor freight maybe they have it. 52 bucks is alot for that.
Mcarlo77 wrote:I bought a fan belt tensioner tool years ago for this reason because I just couldn't get the belt tight enough on my '67 Cougar. Only one like it I could find just now is this one...and, I'm certain I didn't pay anywhere near this much for mine. One of those tools that are seldom used but sure come in handy when you need it. You could wedge it between the a/c compressor body or pulley shaft and another nearby component and tighten it.
Do you believe I found the tool,thought we broke it.
Good to hear...it's a great little tool to have around!
