Chevelle vs Monte Carlo Alignment Specs
I was looking at the alignment specs on G3 Chevelle vs Monte Carlo and the Monte Carlo has way more caster at 5 degrees vs 2 degrees on the Chevelle. As far as I know the control arms, shaft and all else in the front ends are the same. So is there any issue using the Monte Carlo specs on my Malibu? I'd imagine the extra caster will considerably improve the road feel.
1975-77 Chevelle with PS (earlier cars have less caster)
Caster
+1 1/2 to +2 1/2 Desired +2
Camber
Left +1/2 to +1 1/2 Desired +1
Right 0 to +1 Desired + 1/2
Toe In
0 to 1/8"
1973-77 Monte Carlo
Caster
+4 1/2 to +5 1/2 Desired +5
Camber
Toe In
0 to 1/8"
Caster
Camber
Toe In
0 to 1/8"
1973-77 Monte Carlo
Caster
Camber
Toe In
0 to 1/8"
76 Malibu- G3GM Member
Re: Chevelle vs Monte Carlo Alignment Specs
On the surface, it would seem to be ok if you don't mind all the extra shims.
One item of note, according to the myriad of literature I have, the Monte Carlo steering box has a different steering ratio than the other Chevelle based cars; yet another Monte Carlo only item . Don't know what difference it makes, if any, but, then again, I'm not an automotive engineer nor do I play one on TV.
zucchi- G3GM Member
Thanks, that is what I was thinking too. There wouldn't be any difference in the control arm mounts between a Monte Carlo and Chevelle chassis that anyone is aware of? I would assume the upper arm mounts at the same angle on both chassis.
I noticed the difference in the specs between the Monte and other A bodies about 1979 when I first entered the automotive repair field. I have had good results over the years with GM cars I have owned moving the alignment shims for more positive caster. The Monte does have a stiffer torsion spring in the steering box for more "road feel", but the box is interchangeable with the standard units.
markmastrangelo- G3GM Newbie
Increasing caster just makes the car track better in a straight line. Turning will offer a bit more resistance the more caster is increased. Also, increasing the caster on the right side about a 1/4 to half a degree over the left makes the car track better on crowned roads. One of the best steering boxes to use is a 2nd gen Camaro or an 81-85 Buick Riviera with the ride and handling package. These are variable ratio and have a stiffer torsion bar in the valve that limits assist. They give better road feel.
Zed06- G3GM Newbie
markmastrangelo likes this post
I just double checked the parts literature and discovered the steering box for 1973 Monte Carlo was unique for that year; P.N. 6258459. In '74, Monte Carlo, Chevelle SS and Sprint with S.P. pack used the same box; 6260559. By December 1990, that part number was discontinued.
zucchi- G3GM Member
» stock suspension alignment specs
» 75 - 77 chevelle 2 or 4 door and monte carlo electric??
» NOS Black Dash W/AC 74-77 Chevelle Malibu Monte Carlo
