stock suspension alignment specs
Page 1 of 1 • Share •
hey guys, at work about to do an alignment on a g3...what are good specs for alignment that you guys recommend..im talking everything, camber, caster. etc.
im here until 6 so anytime before then...any help is greatly appreciated.
- Street Cred: 6
Re: stock suspension alignment specs
bascially i forgot the specs and i cant find them online...our alignment computer only goes back to g bodies.
- Street Cred: 6
Would one of those Haynes manuals have that info? Cause I've got one of those for a A-bodies up to '77
IndyG3- G3GM Enthusiast
- Street Cred: 11
it should..im basically just trying to find the caster/camber/etc all the specs...i had them written down my girlfriends dad had a book and i cant find the specs he gave me.
- Street Cred: 6
Found it, but the numbers are...confusing, at best.
- Street Cred: 11
IndyG3 wrote:Found it, but the numbers are...confusing, at best.
haha well ill see if i can hunt my stuff down then..if youd like to post it anyways go for it ill compare to what i have, if not, thats cool too...either way i appreciate you looking up the stuff for me.
- Street Cred: 6
All it has is the caster and camber angles.
for 73-74 El Caminos with manual steering, caster is 1 degree plus or minus 1/2 neg. Camber for the left is 1 plus/minus 1/2. Right is 1/2 plus/minus 1/2.
For Chevelles (power steering), caster is 0 degrees plus/minus 1/2 degree pos. Camber, left if 1 degree p/m 1/2. Right is 1/2 p/m 1/2.
Unless you have an El Camino from a newer year than that.
- Street Cred: 11
Similar topics» Thanks Wayne for the Suspension up grade.
» Arctic Cat Valve Clearance Specs...
» Stock Car Evolution Paint Schemes
» Genuine Magpul UBR stock for m4 in black
» ShopNBC, Sans Host Jim Skelton, Floats Stock Offering
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» ~~Introduce Yourself~~
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
