1973 4 door chevelle Max rear Wheel & tire size?
Hi i want to fill up my rear fender to the brim, what is the widest size 15" rim that will fit? and what backspacing? Whats the biggest tires that will fit? I might option for a dragrace slick or similar.. Im going for dragrace look.. huge big balls in the back, and some really skinny tires in the front
huse- G3GM Newbie
Re: 1973 4 door chevelle Max rear Wheel & tire size?
Guess it all depends on what you want to do.
- You want them to fully tuck?
- You modifying the inner lip at all?
- Going with the airshocks?
BTW - The front wheel wells are freaking huge too. Some really skinny tires are going to look even skinnier under that thing.
74Malibu383- Donating Member
Fully tucked, with hijackers, no modification to the inner lip. what's the biggest i can go?
huse- G3GM Newbie
Sorry... don't know what hijackers are...
325/50R15's on a 15x10 or 15x11 with 5 5/8" backspacing.
74Malibu383 wrote:Sorry... don't know what hijackers are...
WHAT BUDDY YOU DONT KNOW WHAT GABRIEL HIGH JACKERS ARE ??? BETTER KNOWN TO THE NON STINK BUGGERS AS AIRSHOCK'S
And as far as wheels for our cars with no fender work being needed on a 15" wheel only I have found is 10" maybe an 11" but very happy with the 10" with 4.5" and a 295/50/15 or a 275/60/15
Lol. Sorry, guess I need to brush up on that stuff. Jacking up the rear end doesn't help the pinion angle if you know what I mean...
Well, if he's using Hijackers, Highjackers, or Airshocks (Gold Jacket, Green Jacket, who gives a s...) then nothing will need to fully tuck. If it were being lowered, then it matters.
o yea I know what you mean buddy
sorry, my bad.. By tucked i though you meant to the side not as in lowered.
Sorry if my english is alittle bit off, im norwegian
So 325/50-15 is the widest tire i can get in the wheel well at stock ride height?
huse- G3GM Newbie
I have a 73 chevelle 4 door and i have 15X8 with 10 inch wide tires and air shocks it rubbed a little bit b4 so thats why we put air shocks on and i dont leave them up very high at all and it works and looks fine!
1973chevelle- G3GM Member
» 1973 Chevelle Best Tire Size for All Four Corners
» 75 wheel/tire size help
» 1974 chevelle rear end size?
