73-77 Big Block with A/C Question
maliburacinfreak
Page 1 of 2
First I would like to say,
Hello and thank you for letting me join this forum.
I was wondering if anyone here had some pics of a 73-77 Chevelle with a 454 and A/C.
Or maybe a pic of the shop manual with the bracket install procedure.
I have the brackets in a box and I am not fimilar with the Big Block power steering & A-6 compressor setup.
Thanks
Thanks
TURNA- G3GM Newbie
Re: 73-77 Big Block with A/C Question
I wish I could help some, but I'm a small block guy. I just wanted to say welcome to the forum & nice Malibu! Feel free to post about it as well on the later gen sub-forum.
Hey whats up !? I can take a picture of my 73 Monte's set up (stock 454) for you. but Im heading out the door right now. What part of the assembly are you not sure of ?
I am try to piece together the power steering and AC brackets.
I know the large plate goes on front of the block after that I'm clueless
I'm not sure which exhaust port the one bracket goes over since I can't get the bolt holes to line up.
and I know one bracket goes in front of the compressor and one in the back but not sure which is which since I dont have the compressor yet.
Thanks for your help!
TURNA- G3GM Newbie
Here are some pics of mine back in 2002,when everything was still original.
Thanks Im going to go see what im doing wrong now!
TURNA- G3GM Newbie
AHHHHHH finally
Well sort of
I was so convinced that the one bracket bolted to the exhaust manifold.
I completely overlooked the 2 bolt holes on the head above it, that the small AC bracket bolts too!
I have to modify the bracket since I am using headers but at least I have a better idea of placement now.
Thanks !!!!!!!
Well sort of
Thanks !!!!!!!
TURNA- G3GM Newbie
TURNA wrote:AHHHHHH finally
Well sort of
I was so convinced that the one bracket bolted to the exhaust manifold. on a sbc it would of.
I completely overlooked the 2 bolt holes on the head above it, that the small AC bracket bolts too! I'm glad I found the pics.
I have to modify the bracket since I am using headers but at least I have a better idea of placement now.I will have to do that one day,if i ever put the a/c back in.
Thanks !!!!!!!
There shouldn't be alot of work to it.Looks like just a little difference.
BOY do I need to clean up my headers
welcome aboard TURNA!
maliburacinfreak- Donating Member
Since you dont have the A/C installed anymore can you snap a pic of the power steering pump?
Thanks again
Thanks again
TURNA- G3GM Newbie
TURNA wrote:What is this bolt going into?
the water pump
the threaded hole all the way to the right.
ahhhhhhhhhhhhhhhhhhhhhhh
No wonder I couldnt figure that out
I have the reverse rotation pump on the engine from the serpentine setup i was going to use.
I can't thank you enough 1973 454 MONTE !!!!!!!!!!!
TURNA- G3GM Newbie
TURNA wrote:ahhhhhhhhhhhhhhhhhhhhhhh
not a problem dude,thats why we are all here
Here is a pic of the modified lower A/C bracket along with an unmodified one.
TURNA- G3GM Newbie
Looks better than the original one.
BlackChevelleSS- Management
UGGGGG!!!!!
Any chance you have a pic of your alternator with brackets?
The fan on my alternator is hitting the brackets.
TURNA- G3GM Newbie
problem solved
went back to the parts store looked at a different one and it was a completely different fan on the alternator
TURNA- G3GM Newbie
Had to cut up and grind away the top AC compressor suppoprt bracket to clear the taller valve covers.
TURNA- G3GM Newbie
Ok one more annoying question.
Your power steering belt. Can you read the part number on it?
All the ones i am seeing are listed as steering, fan, crank.
I only have a 2 grove pulley on my water pump.
I see that you have the belt that goes from crank to pump and that what I need, but cannot find.
TURNA- G3GM Newbie
TURNA wrote:Ok one more annoying question.
i cant see a # but go to a parts store and see what they have listed for a 73 MC with a 454 with NO a/c.
TURNA wrote:great thanks
did you get one?
» LOOKING 4 MY OLD BLOCK
» Question on block water jacket holes
» El camino on the block right now for 2k buy it now.
Page 1 of 2
Today at 5:49 am by 73 ss wgn
Yesterday at 9:31 pm by Limey SE
Yesterday at 4:39 pm by chevelleman
» Window louvers
» 1973 Chevelle SS 1 Family
