control arm bushings
Page 1 of 1 • Share •
does anyone know how too measure the lower front control arm bushing and why is the front bushing a different size then the rear on the front lower control arm
billy-ray- G3GM Enthusiast
- Street Cred: 13
Re: control arm bushings
Small bushing specs--front lower
Dimension A O.D. : 1.36"
Dimension B I.D. : .51"
Dimension C Length : 2.4"
Dimension D Length : 2"
Dimension E Length : .23"
Dimension F Length : .56"
Dimension G O.D. : 1.42"
Big bushing specs--front lower
Dimension A O.D. : 1.65"
Dimension B I.D. : .57"
Dimension C Length : 2.41"
Dimension D Length : 2.03"
Dimension E Length : .24"
Dimension F Length : .32"
Dimension G O.D. : 1.67"
Lower rear bushing specs
Dimension A O.D. : 1.9"
Dimension G O.D. : 1.92"
As to why the front is different than the rear, I don't know. I speculate that the lower rear have greater force loads than the other ones.
bigredlaguna- G3GM Enthusiast
- Street Cred: 31
so the lower rear is the same regardless of the lower front size
- Street Cred: 13
billy-ray wrote:so the lower rear is the same regardless of the lower front size
Yup.
- Street Cred: 31
If your rebuilding the rear suspension as well I recommend making the lower control arms as stiff as possible. boxed control arms are good but Tubular arms are better. Use poly bushings or solids on the lowers but use stock rubber on the uppers if the stock arms are used because the rear suspension will bind if you dont. I like the adjustable uppers that use a heim joint on one end to help eliminate binding.
- Street Cred: 13
Similar topics» STEP COURSES FROM SIEMENS (AUTOMATION AND CONTROL COURSES)
» Write-Up: 1996-1997 Front Control Arm/Bushing Replacement
» 95 s/c rivi steel control arms
» Upgrade your sway bar link bushings on a 02 - 03 Nissan Sentra (B15 Chassis)
» Front control arm bushings
» Just some pics
» window sweep
» 75 cutlass cheap
» 73' Chevelle (Malibu) Interior Plastics
» NO...NO...NO...
» 75 cutlass
» Wallys 73 Malibu project
