gauges lighting problem
G3GM :: G3 Tech :: Electrical
Page 1 of 1 • Share •
Hi Guys ,
since I own my 75 Chevelle Sedan , the dashboard lighting never had worked . Now that winter is coming , I'd like to have a properly lighted dashboard .
I took the dashboard cover out today , but couldn't find the light bulbs , but one which lights the wiper switch .
That bulb was OK , I checked it on my Ohmmeter . So I presume all the other bulbs must be fine
Wich fuse should I look at to be sure I'm looking at the right one ( don't want to break them all
Could it come from the light switch's variable rheostat ?
Any other idea ?
Many thanks !
Laurent
Any other idea ?
Many thanks !
Laurent
the Baron- G3GM Newbie
- Street Cred: 0
Re: gauges lighting problem
If none of them work then I would suggest replacing the headlight switch. thats what was wrong with ours.
- Street Cred: 13
Hi BC !
are those lighting switches specific to the 73-77 models or will all the GM switches from the 70's fit just right on ?
Many thanks !
Laurent
Many thanks !
Laurent
- Street Cred: 0
Since it's all of them, I agree, if it's not the fuse, then the headlight switch is most likely. You have to remove the entire cluster to get to the bulbs. They're a wedge based #194 type.
Has anyone used the LED replacement types?
Oidar- 2011 Donating Member
- Street Cred: 0
the Baron wrote:Hi BC !
Many thanks !
Laurent
I think most GM cars shared the same headlight switch. As I know our 73 Chevelles and my 70 Chevelle and our old junker 80 Citation all had alike headlight switches
- Street Cred: 13
the leds are expensive as hell but they look really cool i got one in my temp gauge and it over powers all the other ones if they werent so expensive id do em all but money is scarce
billy-ray- G3GM Enthusiast
- Street Cred: 13
I was going to hide some LED strips above the cluster to make it brighter, now i wonder if these LED replacement blubs are bright enough? I have to buy a set and try it out.
orange Juiced- 2010 Donating Member
- Street Cred: 6
Hi Guys,
it was just the fuse, just call me moron, right ?
Regards,
Laurent
Regards,
Laurent
- Street Cred: 0
Wow, I must really be uncool. First black primer is out, now it's not cool to have that old green glow in the dash??? I really need to start catching up on the trends.
- Street Cred: 48
badbiscayne66 wrote:Dont ever follow trends!!!!!!!!
If I was a trend follower, I would own a Pro Touring Camaro on 18 inch rims instead of a G3 Chevelle. That ain't gonna happen
- Street Cred: 48
Similar topics» mazda dpf problem
» B5.5 Passat coolant problem
» Nokia C2-01 Insert SIM Problem Solution
» Flyff start up problem
» Patch problem becouse server down?
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» ~~Introduce Yourself~~
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
