76 GMC Sprint Gauges
I'm looking to upgrade the gauge cluster on my 1976 GMC Sprint. It currently has the round gauges and I simply want to replace them to make it look as original as possible. I have been considering going with Dakota Digital gauges, but they have never built a custom gauge cluster for the 1976 GMC Sprint. Has anyone had any experience with replacing/upgrading the gauges on the 4th generations? Any feedback would be greatly appreciated.
Sammy384- G3GM Newbie
Re: 76 GMC Sprint Gauges
Does your existing round cluster have the idiot warning lights...or, does it have the small Fuel, Temp, Volt and Clock gauges? If the latter, why not buy a decal kit that restores them to look exactly like the originals?
Well, they are all original but they need to be restored. It had a fuel efficiency gauge that I would like to replace with a tach. Also, it has a clock that I would like to relate with voltage.
Sammy384 wrote: Also, it has a clock that I would like to relate with voltage.
Not exactly sure what you mean by this as you already have a Volt gauge.
Biggest challenge is replacing the large Economizer gauge with a Tach...and, have it look original. Not aware of any aftermarkets that will look and fit like the original. Someone else can maybe chime in if they've found something. I can offer up some info if you want to restore your small gauges. I've restored several of these clusters and there is some info to be shared if you can find an original Tach cluster cheap that is in need of repair.
Oops! My mistake. It does currently have a volt gauge. I want to replace the clock with an oil gauge.
Mcarlo77 wrote:Biggest challenge is replacing the large Economizer gauge with a Tach...and, have it look original. Not aware of any aftermarkets that will look and fit like the original. Someone else can maybe chime in if they've found something.
Most gauge manufacturers only offer 3-5/8" and 5", which are way too small and way too large, respectively. After a lot of searching, the closest thing size-wise I have found are the VDO units -- they make a 4" tach and speedo, which look reasonable IMO. Really for an exact fit you'd need something about 4-1/2".
Turn you fuel gauge into a tach
https://www.g3gm.com/t8625p100-dead-tach-need-tach-filter
I installed new smaller fuel, volt, oil and temp gauges but to do this, you will need to trim the bezel and bracket to make them fit.
Hawk03- G3GM Enthusiast
Hawk's method is certainly the best for retaining the stock appearance!
Agree. You can even buy some black decals w/white lettering to further it's stock appearance.
» Swapping dash and gauges. Going from 77 malibu w/ idiot lights to 73 el camino ss with round gauges
» $$$ Autometer Gauges $$$
» Looking for Gauges for 77 Monte Carlo
