winter storage time
Page 1 of 2 • Share •
winter storage time
I washed the Malibu today, to get it clean for the car cover. It's stored in my partner's hangar at the local airport. The Malibu didn't even get on the road this past summer. I did run down the runways with it every few weeks, just so it was warmed up etc. Too much going on this summer to drive it. Last summer it got only about 800 miles on it. Kind of expensive by the mile that way, so this year, it "rested"
most of the time. Probably have snow here in another month......
pila- 2012 Donating Member
- Street Cred: 17
Re: winter storage time
Same story on my end. Probably only put 200 miles on my Monte Carlo this summer. Now, with winter looming on the horizon, it will soon be time to "winterize" it and put it under wraps to end another season of cruisin'. You guys living in the South have no idea how lucky you are to be able to drive all year 'round!
Mcarlo77- 2012 Donating Member
- Street Cred: 17
- Street Cred: 48
Get out and drive them, guys!!!!
I've probably put almost 10,000 miles on my Cutlass this summer.
Drove it every single dry day, got caught in the rain once. Still driving it right now, will put it up next month.
Cars are for driving, not for sitting! Enjoy them while they last fellas, life is short!
MichiganMuscle77- G3GM Member
- Street Cred: 2
Good point, Michigan Muscle! I tend to drive my car until it starts snowing. In Indiana, that normally means I get to enjoy it until January or so. Then it sits in a garage and I start it every couple of days (I don't get out much in the snow...)
IndyG3- G3GM Enthusiast
- Street Cred: 11
I agree whole-heartedly! I wait all winter long for the chance to get the Monte back out of storage and on the road...and, every Fall, I sit back and wonder where the summer went and why I didn't take the time to drive it more often. In good 'ol Minnesota, the typical driving season for classics is pretty much May 1 - Oct. 31. I've occasionally driven mine into the middle of November...but, that is rare. We've usually had snow by that time and the "salt shakers" have been out in force with their road chemicals. Likewise, in the Spring, everyone waits until we've had a few good rains to wash the chemicals off the roads.
- Street Cred: 17
I got mine almost ready for storage also. We pulled the dash, so between getting that restored and finding all the other parts I need for the interior, we have enough work to last us through the winter. Come spring, we'll have our hands full putting at all back together again. I have to take the car out one more time to wash it, then put it back in the locker, put the cover on and pull the battery. I'll miss the car a lot, but it has to be done. These Wisconsin winters are brutal.
HDHugger- G3GM Member
- Street Cred: 6
I also will agree once i can drive, These NewHampshire winters are also very bad, and yes the "Salt" or salt/dirt/sand is dropped and i will not drive my car
lars- G3GM Member
- Street Cred: 1
Michigan winters are bad, too. I don't drive in the snow or the rain. After winter, I wait until one good rain before I bring my car out, that way all the salt is washed off the roads.
But during the summer... any nice day, I'm driving it.
- Street Cred: 2
Okay...for the benefit of all us Northerners...maybe some members can their routine for putting their cars away for the season. In other words, what do you do to prep them for storage?
I used to be very anal about washing, waxing, wiping down the interior with conditioner, vacuuming, changing oil, greasing the joints, flushing the radiator, filling the tank and adding SeaFoam and laying a plastic tarp on the garage floor to prevent moisture from leeching up from the concrete and rusting the undercarriage. Now, I've gotten much lazier and basically wash the car, maybe change the oil, fill the tank and add the SeaFoam. Speaking of filling the tank, up here in the Land of Ethanol gas, I only use the Non-oxygenated Premium that is availabe at certain gas stations. It doesn't absorb moisture over the winter months like ethanol does. Makes for better starting in the Spring.
- Street Cred: 17
Wash, squeegee (look up California Water Blade, best $8 you'll ever spend - I PROMISE), chamois, wax, let fully dry. If you have an air compressor, use it to blow water out of cracks and seams.
Armor-all interior, use leather treatment on the leather.
Dryer sheets all over the interior, pick your favorite scent - they keep mice away AND your car smells great when you pull it back out in spring. Smell lasts maybe a month more after coming out.
Inflate tires to max pressure if they're going to be on the ground, use some sort of rubber conditioner on them if it's going to be extended storage. Same goes for weather stripping. Silicone spray works, spray it onto a shop rag and wipe weather stripping down really good. Also works on your DD so the doors don't ever freeze shut.
Fill gas tank so there is less area for condensation to form on the inside. Use dry-gas after filling the tank.
Get a carburetor cap. Drain fuel bowls. Remove battery, I store mine in my bedroom closet - 3 years on now and has never needed a charge when I go to get the car back out.
Here's a video of me starting my car up after storage this previous winter.. it was January 31st and somewhat warm, roads were dry, so I gave into temptation and took her out.
Had not been started since late November, so about 2 full months of storage.
http://www.youtube.com/watch?v=g14qtJ_5FC4
DON'T change the oil. I usually get about 2000 miles or so on my oil before storage. The big time car collectors say that when you store a car, used oil won't be quite as thick as brand new oil when you go to start it - that way it'll flow through the motor better.
Change the oil after you've started and driven your car for a considerable amount.
After starting, don't just let it run for a few minutes and shut it off - condensation will form in your exhaust from the change in temperature, and if you don't let it heat all the way up, it'll sit there and start rusting.
Take it out for a long drive after bringing it out for the first time. Start off at cruising RPM's, don't beat on it... once the engine has been at operating temp for a little bit, then stretch the RPM's out a bit to help clear out old gas and carbon build up.
A little spray of WD40 in each cylinder before storage will keep the rings from sticking.
- Street Cred: 2
very good advise brother well put ...............
- Street Cred: 60
Some great advise here, I have just one thing to add. I put moth balls in the trunk and in the floorboards and under the hood near the top of the cowl and on intake manifold. I use empty cereal boxes to protect floor mats and carpet. Trouble is them moths really scream when you...oh, did I mention that I put the car on jackstands? JB
- Street Cred: 21
I put 100 octane Avgas in mine, which doesn't leave the crappy residue from ethanol. Of course the additive Sta-bil works good too, and I use it i my lawn tractor and emergency generator.
The battery died in the Malibu a moth ago, so it will get a new one in spring. It's five years old, so it did good!
- Street Cred: 17
I haven't put my MCs away for the winter yet, but probably soon. I usually wait until the snow and salt fly....
I've put ~900 miles on each of them, not sure if I'll make it to 1,000 miles on each of them like I did last year or not..... We'll see in a few weeks...lol.
Cort | 37.m.IL.pigValve.pacemaker | 5 Monte Carlos + 1 Caprice Classic |* Chicagoland Meets, 2011?
"This is not where you belong" ... Restless Heart ... 'Why Does It Have To Be (Wrong or Right)?'
knightfan26917- 2011 Donating Member
- Street Cred: 3
Similar topics» SPECIAL FIXED MATCH HALF TIME / FULL TIME FOR 08.04.2012
» ROD STORAGE SOLUTIONS FOR RESOURCE
» Winter in Fairbrook
» winter centralia run
» Winter meets....
» Winter meets....
Page 1 of 2
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» ~~Introduce Yourself~~
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
