New guy here from Florida
+17
skeezix91
jurgenday
21 posters
Page 1 of 11
Page 1 of 11 • 1, 2, 3 ... 9, 10, 11
Hey guys after searching and searching for a good Fourm for a Laguna I think I finally found one haha and there dosent seem to be many out there lol,
But I just purchased a 1975 Chevelle Laguna S3 with a 350 that was swaped from a 400, th350 3 speed , posi rear end, needs some body work here and there but its a good driving car I got it to be my daily driver.
thepossumface- G3GM Member
Re: New guy here from Florida
Welcome to the sie fellow 'Guna-man! Make sure to register it on the National Laguna S-3 registry.Look in the forum for the thread to check out. We are trying to find out how many are left and it could also help to increase awareness and possibly value. It's cool, anyway!
Pontichev327- G3GM Enthusiast
Welcome. Try sending limey a pm about Laguna nose parts. He was trying to sell a complete one very recently, and has ( I think) resorted to parting it out. I always did like lagunas.
Last edited by dynchel on Fri May 03, 2013 7:13 am; edited 1 time in total (Reason for editing : added details)
That's a good look'in ride man. A lot of potential. Welcome to the site!
dynchel wrote:Welcome. Try sending limey a pm about Laguna nose parts. He was trying to sell a complete one very recently, and has ( I think) resorted to parting it out.
Ditto. Just last week he was threatening to junk it 'cuz he didn't have any takers. Looked to be in decent shape, too.
thatfnthing wrote:dynchel wrote:Welcome. Try sending limey a pm about Laguna nose parts. He was trying to sell a complete one very recently, and has ( I think) resorted to parting it out.
Sorry Boss I offered it to you on Facebook and said it was to far Its been sold for parts, But Welcome Aboard My friend Glad to see you found us a lot of Great people here
Welcome gonna make one heck of a daily driver!
Tom77- Donating Member
thanks guys, yeah I saw his one facebook and if it wasnt for the freakin shippin I would have got it in a heartbeat, but it will come one day. what kinda HP/tourqe are you guys looking at on yours? I think i read that mine has like 160hp and its kinda slow, but im working on finishing up my HEI swap with a edelbrock intake. figured that may help some.
Dont you already have a hei? 1975 it became standard on all gm vehicles (along with catalytic converters)
negative Boss, im not sure which motor this came out of, because its "suppose" to be the 3rd egnine in this car it had a 400 in it before this, and this motor had the points disturbtor in it and it started acting all wierd so instead of fixing it i wanted to upgrade to the HEI dizzy. so who knows what this car has been through.
But does anyone have a wiring diagram? I need to know which wire to hook up to the Hei so i can start it and time it correctly.
But would a el camino front fit? I came across a few there parting out it looks a little different than mine but its a 70's model
or will just a laguna front fit? this may just be a temp fix till I get a solid stock one, one day....
El Caminos will fit till you find the right nose, just make sure to get the core support as well if a dual stacked headlight it might be different and better to be safe then sorry and stuck, and let me dig out my diagram for you if I can remember what folder I put it in
welcome aboard
good starting point you got there.
thanks! Its got bigger tires on the back with crager rims and deep dish in the rear I realllly like that lol, but better news Is i found that wire for my 12v to run to HEI and cranked up and runs 200% better with the new intake on it..
now I gotta get me some headers and a new edelbrock carb
but now looks like im having a issue sense I put the new valve covers on it started leaking oil alll over so i went to change the oil and saw it leaking out the back side went to remove the bolts and one broke off on the head , but i tighten the others and seem to work, but I drove it across town before knowing it and i guess it leaked out all the oil (no oil light came on at that)
and now It wont crank after I tighten the bolts and put a little oil in it, i didnt hear any knocking but it did smoke from the rear and I see were oil was on it, yall think the motor is done? I reallly hope not..
thepossumface wrote:now I gotta get me some headers and a new edelbrock carb
I have access to some headers if you figure out if you smoked the motor ( NO PUN INTENDED ) Pretty cheap also
my motor is good the 12v to my Hei fell out LOL, but ill need new valve gaskets they leak but its running great, thank god i wont have to get a new motor,
ok guys so i put on new valve cover gaskets and the right side on the back is still leaking, i tried rubber ones and the pass side leaked so i switched to cork and now only driver side leaks on the back any idea's? im stumped.
Valve cover may be warped. Do you hav e spreader bars to more evenly distribute the force of the valve cover bolts? They do help.
Long washers (for lack of another term) that go on the cover, under the bolt, that spread the load. If a steel valve cover gets over tightened it pulls down under the bolts and lifts her in other areas causing leaks. If you take the cover off and look at the flange it has to all be flat, if around the bolt holes is peened you found the problem. Hope this helps.
They're these: valve cover load spreaders
They effectively give you eight points of pressure along the rail instead of four, and are more evenly spread out.
thatfnthing wrote:They're these: valve cover load spreaders
Be sure to staighten the valve cover sealing edges first, all the holes have to be flat with the rest of the rim, and careful not to slide the gasket when installing. Come down FLAT on the heads. AND DON"T OVER tighten them.
Just as a side note, general motors switched to center bolt valve covers (1987) to help prevent valve cover leaks.
Page 1 of 11
