Rear rocker trim.
Rear rocker trim.
Post by 74MonteCarlo on Tue Oct 04, 2011 5:43 pm
After I was cleaning rubber off of my car last night from a burn out, I though I'd take off the two rear rocker trims, and polish them on the bench. Turned out pretty nice. The body is very clean underneath.
Trim before:
Body before wash & wax:
Trim after polish:
Body after wash & wax:
Everything back together:
Street Cred: 16
View user profile
Re: Rear rocker trim.
Post by 77mali on Tue Oct 04, 2011 6:13 pm
Looking good!
2012 Donating Member
Street Cred: 14
View user profile
Post by 74MonteCarlo on Tue Oct 04, 2011 6:25 pm
Thanks!
Street Cred: 16
View user profile
Post by 1973 454 MONTE on Wed Oct 05, 2011 5:14 am
you did a burnout in the monte????????????????????????? tisk tisk
looks a lot different Thumbs up
i have one question. why does your wheel well molding stop at the lower molding?
now i see. somebody took off the factory style.
Street Cred: 26
View user profile
Post by ant7377 on Wed Oct 05, 2011 5:31 am
Might want to address that surface rust there. Clean it up and put some rust killer type product on it.
Street Cred: 12
View user profile
Post by 77mali on Wed Oct 05, 2011 5:42 am
ant7377 wrote:Might want to address that surface rust there. Clean it up and put some rust killer type product on it.
Por15 works awesome & coverage is excellent. Just a light sanding (not to bare metal & blow off the "dust") it actually bonds to rust & you can leave as is since the cover will go over it. Do both sides though.
Street Cred: 14
View user profile
Post by ant7377 on Wed Oct 05, 2011 6:28 am
Coroless from Eastwood works well too.
Street Cred: 12
View user profile
Post by 74MonteCarlo on Wed Oct 05, 2011 8:52 am
1973 454 MONTE wrote:you did a burnout in the monte????????????????????????? tisk tisk
Yes. Yes I did. I laid down over 55' of rubber on the ground.
I have no idea what happened to the original wheel opening moldings. It was the way it is when I got it. Sad
I do know, at some point in time, it was painted around the wheel openings. maybe the originals were dinged up. The original owners were quite old, so maybe they hit a few things...lol.
Street Cred: 16
View user profile
