Oil Pan Install
Oil Pan Install
When I took off my old oil pan there were 2 steel "reinforcement bars". If I remember correctly, they were on the block surface on top of the old gasket that was a non reinforced type (very flexible). My question is now that I have a reinforced gasket, should I still be using the old bars? I've still seen them used with the new type of reinforced gasket that I have but installed on the exterior side of the pan instead. Maybe they were installed wrong previously?
Re: Oil Pan Install
only bars ive seen is speader bars just under bolts on top if pan its self those ya can other wise i didnt on my felpro one pcgasket
Re: Oil Pan Install
Later 350 Chevy engines used them on the bottom side of the pan rail. My '93 Fleetwood Caddy had a Chevy engine with those reinforcement bars. They must help some, or GM wouldn't have spent an extra dime to put them on. My '93 Buick has them also.
Re: Oil Pan Install
The block I have was cast in 88 it looks like. The gasket is real floppy compared to the new one & I had to check. Thanks guys! I think the new seal is a bit thicker too where it meets the timing covers & real main seal.
