Suspension upgrades
Suspension upgrades
I’m looking to do a few upgrades over the winter:
New coil Springs- Belltech 2 inch lowering springs all around.
Bilstein shocks (Have these on both daily drivers, a must have)
New steering box - 12:1 quick ratio
Any thoughts on the Belltech lowering springs, anyone use them or have any good recommendations?
Eventually:
Upgrade the front sway bar and add a rear bar (No rear bar currently, nor the holes to mount them) Upgraded rear trailing arms, new bushings & front end rebuild. Upgraded 17inch wheel/ tire package then move toward bigger brakes.
As you can tell I want this thing to handle, any input is appreciated!
Eventually:
BK-75- G3GM Member
Re: Suspension upgrades
The quick ratio steering box is a good idea. I put one in my '74. Maybe someone here can make a template of the hole locations for a rear bar., for you to add mounting holes in yours.
Bill
Bill
more thoughts on the box, quicker ratio helps alot but you also want to look for Torsion bar size which helps with the road feel and return back to center, Then also the spring and piston inside the PS pump will make alot of difference in how easy it is to turn.
You want the largest torsion bar you can get, im still working on figuring out how to fix the pump.
You should also upgrade to 1-1/4 front sway bar, boxed or tubular rear lowers and a 1" rear sway bar. It will keep the car flat around the corners.
BlackChevelleSS- Management
I got my boxed rear lowers with polyurethane bushings from Spohn. They are super nice and have sway bar holes built into them.
Brainstain- Donating Member
Here is an article about how to change the power assist at the pump. Very simple, just need to be careful.
http://westtexasoffroad.homestead.com/powersteering.html
Keep in mind that the link talks about INCREASING pressure and volume. All you really need to do is add shims to decrease the pressure.
bigredlaguna wrote:Keep in mind that the link talks about INCREASING pressure and volume. All you really need to do is add shims to decrease the pressure.
So, decreasing the pressure will actually give it that firm heavy feel?
BK-75- G3GM Member
An 80's monte SS steering box is quick ratio. If I remember correctly, I put on in my buddys 72 cutlass. And there was a "washer" that we had to put in the end of the pressure line, I believe to increase the pressure of the pump. Just going from memory here, but the monte box was a bolt in. His steering felt real "nice and responsive" after that bolt in.
BK-75 wrote:bigredlaguna wrote:Keep in mind that the link talks about INCREASING pressure and volume. All you really need to do is add shims to decrease the pressure.
Yes.
Joe73, that "washer" was probably an adapter that converted the gearbox's O-ring fitting to a flare fitting so he could use his original lines.
bigredlaguna wrote:Joe73, that "washer" was probably an adapter that converted the gearbox's O-ring fitting to a flare fitting so he could use his original lines.
Possibly so, but I think that the monte box needed more pressure so the "adaptor" had a smaller hole to increase pressure. Just going from memory hear, but it was a real easy bolt in upgrade.
If anyone is thinking of putting a quick ratio box in there car, just search monte SS steering box on google. Tons of info regarding the swap.
I found this for a quick read with good info. http://www.carcraft.com/techarticles/ccrp_0901_gm_steering_box_upgrade/viewall.html
My chevelle didnt come with power steering and I like it that way. But still a nice up grade.
Today at 7:18 pm by 76Chevelle2Tone
