A question for anyone who has done a frame off.
I'm at a turning point with with my 73 restoration and would appreciate anyone with experience chiming in. I have the body on the rotisserie, all sheet metal prepared and primed, and have a complete set of body bushings from the parts place. The frame is cleaned but I haven't done any blasting or painting on it.
1) Would it be better to bolt on the body, fenders, core support, hood then align and paint on the bare frame, then remove, tagging all the shims for future install? Then blast and paint the frame, reassembling the body on a finished frame?
2) Or complete the frame work before installing the body for paint?
I have access to the equipment and manpower to switch the body without much trouble. I've watched several shows and videos about frame offs and they seem to go with option 2. What I don't have is equipment or expertise with painting the body so all this has to be paid for at shop rates of $45.00 / hour. I'm looking for the option that produces the best results.
Lovett- Donating Member
Re: A question for anyone who has done a frame off.
Option #2 is my choice. Do all your frame work first, then put the body back on and do your body work and paint. Just be careful around the chassis and mask all areas off good. Reason being that the body body have "play" in them when installing. Everything might not line up exactly the same as when you took it off. When your putting the body back on just take a look on both sides of the frame in the rocker area. Make sure the distance, frame to rocker is about equal on both side.
X2. I'd paint the floors and firewall while its off. finish frame and mask mask mask.
No. 2 is what I did. Not saying it is right but it worked well for me. https://s1085.photobucket.com/albums/j438/bud83man/
I installed the body after the frame was finished and all running gear was rebuilt or replaced.
I had the body sand blasted all over except the finish paint areas, and then painted the fire wall, interior, and the whole bottom before re-mounting the body.
Here's a link to the photos of the project. It's an El Camino, but mostly the same process.
https://s561.photobucket.com/albums/ss52/steelybill/El%20Camino%20resto/
awesome pictures pila .... thanks
alleyball4- Donating Member
Thanks to all for sharing your experience and photos. I ordered the metal prep, POR15 and chassis coating today. Should be ready in 2 weeks for the body install.
I have only attempted one(and it is not finished yet ) but option two is the way I went and it has gone well so far!
73 SS owner- G3GM Member
