floating guages
G3GM :: G3 Tech :: Electrical
Page 1 of 1 • Share •
floating guages
all my guages (fuel and speedometer) float around and i can never tell what the actual reading is. i know its most likely wiring but could it be the fuse(s)???
MallyMal S-3- G3GM Member
- Street Cred: 0
Re: floating guages
Nothing you can do about the fuel guage. They all float. Unless someone has a fix I don't know about.
If the speedo is bouncing, try taking the speedometer cable out & cleaning it or replacing it if necessary. That will usually fix the problem. Remember to put some white lithium grease on it when you put it back in.
I don't think either of your problems are electrical, definitely not a fuse. These things just come with the territory of owning an older vehicle.
- Street Cred: 48
Re: floating guages
mmmm not the greatest news lol but good to know. thanks rago. is the cable easily traceable from the guage or would it be easier to know the color why?
- Street Cred: 0
Re: floating guages
Big black cable going from transmission to speedo. Can't miss it.
Just how bad does your fuel gauge float? If I take off hard, mine can drop from 1/2 tank down almost 1/4 & slam on the brakes it will jump up. It's just the nature of our fuel level sending unit. Same goes for taking corners hard. If you have a gauge that's just jumping sporadically you might want to change out the sending unit.
- Street Cred: 48
Re: floating guages
looks like i have to change out the sending unit cause it jumps around a little more than yours. if i knew where it was supposed to be, like the correct level, then i wouldnt be so worried but i dont know when the guage is acyually in the correct position. would it be when im at a stand still? does the car have to be on?
oh and thank you for putting up with me, by the way. ive got a whole lot to learn
- Street Cred: 0
Re: floating guages
If you know that your fuel gauge is working properly, then it will only be accurate if your car is on, and when you're on level ground. Like Rago said before, it comes with the territory of an old car.
IndyG3- G3GM Enthusiast
- Street Cred: 11
Re: floating guages
just a simple way to look at it the fuel gauge is the only electrical gauge on these cars well on mine i only had fuel and speedo. speedo is a mechanical gauge mine bounce a lil but like Rago if i mat the gass i can visually lose a 1/2tank or more but lock up the brakes and all comes back
i love it when cars can make their own gasoline hehe
Redsway76- G3GM Member
- Street Cred: 0
Re: floating guages
if your gas gauge is bouncing around erratically, check the ground wire that goes from the body to the sending unit on the tank, and also check to make sure that the wire from the gauge is making a good connection. your car is 35 years old, and the gas tank always gets crap thrown up at it when you are driving down the road, so things are gonna get crusty.
as for the speedo, take the gauge out and pull the inner cable out and clean it with some carb cleaner. smear smear some graphite based lube on it and stick it back in. this should make it work smoother.
novaderrik- G3GM Member
- Street Cred: 7
Similar topics» floating guages
» "Floating" the driver head at address / setup
» rear full floating axle bolts coming loose
» Going floating this weeking
» vintage moon temp guages
» Engine Mount help
» 1973 CHEVELLE SS 454
» Quarter windows
» Lowrider Regal and Monte
» The new baby!
» Any Bidders out there?????
