New guages needed
Iggy
Keith Seymore
G3GM :: G3 Tech :: Electrical
New guages needed
Hello everybody -
Hope you are all doing well.
It's time for me to get new instrumentation. I'm still running the original factory gauges and they are no longer cutting it.
Does anyone have recommendations, or favorites?
Requirements are (not necessarily in this order): ease of installation (I'm not very electrically inclined), accurate enough for race applications, and closest appearance to the production gauges.
I'm asking specifically about a tachometer, engine temp, and engine oil pressure.
Thanks,
K
Thanks,
K
Keith Seymore- G3GM Member
Re: New guages needed
May not be a price leader, but have you checked out Classic Instruments out of Boyne City? I know they do custom work if you sent them the factory stuff.
Iggy- G3GM Member
Well Well How about this Dakota Digital now offers Gauges for the 1973 -1977 Malibu Chevelle El Camino and Monte Carlo's HELL TO THE YES Choice of Red Blue or Aquamarine(ish) colors |
NO MORE OVERPRICED round gauge clusters ever
[url= https://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=1271/category_id=424/mode=prod/prd1271.htm]
Keith, what about leaving the dash alone and putting an RPM activated shift light? I've seen them set up to be say on the 70-72 Chevelle in the hi beam port in the dash. So its hidden but is right between the 2 center gauges in the highest point of the dash.
I want those Dakota set up. One of you guys get it first and i will see how it goes.
Keith Seymore wrote:Hello everybody -
Thanks,
K
Wow for a race car, it looks production car fresh. Do you still street drive the car?
Thanks -
jerry46765- Donating Member
bracketchev1221 wrote:Keith, what about leaving the dash alone and putting an RPM activated shift light? I've seen them set up to be say on the 70-72 Chevelle in the hi beam port in the dash. So its hidden but is right between the 2 center gauges in the highest point of the dash.
Good idea - I have a shift light and I mounted it up at the very top.
So - when the "tailgate ajar" telltale comes on - SHIFT! (lol)
That takes care of the upper RPM ranges, but I do need a somewhat accurate tach for idle, launch rpm, etc. Using the same technique I have determined that 3000 rpm actual is about 4000 rpm on my factory tach.
I am going to give those Dakota gauges a bit of thought, either as a package or individually.
Thanks -
I have other cars I use to for cruising, or to go get ice cream, but - yes - a little bit.
One of the classes I compete in is called "True Street". The game there is you have to drive 30 miles and then come back and make three back to back passes. You are not allowed to do anything to the car after the cruise except let air out of the rear tires. If you open the hood - you are out. Winners are fastest overall, runner up, and then closest to 9.0, 10.0, 11.0 etc ETs all the way up to 16.0.
I have gone 9.996 at 136mph in that configuration: street trim, through the mufflers, on a DOT tire, licensed and insured.
K
fasrnur likes this post
True Street sounds like something I would be interested in doing. So the car needs to remain a stock appearance or your preference?
I like the fact that you added safety equipment and didn't go crazy trying to gut the car to save weight.
Thanks for the information.
Jerry
Jerry
Keith Seymore wrote:bracketchev1221 wrote:Keith, what about leaving the dash alone and putting an RPM activated shift light? I've seen them set up to be say on the 70-72 Chevelle in the hi beam port in the dash. So its hidden but is right between the 2 center gauges in the highest point of the dash.
Gotcha. Oh well. I have done a bunch of stupid things to protect factory setups. I had an autometer tach with quick disconnects so I could tune and set the idle in my SS 70 Nova so I didn't have to put a tach in it. I didn't think about footbraking and trying to leave the line for starting line rpm. I was a top bulb racer and had a transbrake and a 2 step, so I just put the chip in it and put it on the wood and let it fly!!!!
