heat pipe
heat pipe
Good morning - looking to find info and replacement of my heat stove pipe for the air cleaner - not sure if it's a solid pipe or flexible?? Just trying to finish up converting everything to original again - also would the sizing be different for my 454 or are they all the same? Thanx
RossK73- Donating Member
Re: heat pipe
All my vehicles had the flexible duct from the manifold heat stove, to the neck on the air cleaner snout, except one, which was a '73 Chevelle I owned many years ago...
The local auto parts store usually has a few sizes of the duct in stock...
Re: heat pipe
I have mine for my 73. It's not a flex. Maybe you could get one made at an exhaust shop and just weld a little tab on the bottom for the bolt to hold in place.
Re: heat pipe
I just remembered, that my '74 had a pipe, and it's still around here someplace ! but where ??
Re: heat pipe
I measured the inlet on the air cleaner and got 1.75". All the supply shops have nominal sizes but not 1.75. Can someone send some detail pics against a reference measure so I can get one made......or if anyone wants to sell one would be even better. LMK
Thanx, Ross
Thanx, Ross
Re: heat pipe
I will get you a pic of mine send me your email address
» X pipe
» Where from factory is the stereo radio heat sink mounted and how????
» Outdoor furnace to heat build
