Power Trunk Solenoid Release Install
2 posters
I thought installing a factory trunk solenoid would be easy but I should know better by now. Do I need to cut some sheet metal to make the trunk release work? The solenoid itself installs fine but the flipper? rests on the V cut out (left of the lock shaft) and cannot move to the left when activated to push the lever to unlock the trunk. Am I installing it correctly? It seems like it can only go on one way though. Are the trunk locks different on certain years? This is on a 1977.
Hawk03- G3GM Enthusiast
Re: Power Trunk Solenoid Release Install
Yes...you may need to grind off a little sheet metal so that "flipper" rod can move freely. I had forgotten about needing to do that. Think I used my Dremel with a grinding wheel bit and it didn't take much. I know that probably doesn't sit well with a freshly painted trunk lid...but, just put some touch-up paint on it and you'll be good.
Thanks Steve! Before I cut too much off and have a bigger issue I wanted to make sure that cutting some metal is what was needed. I'll go slow and touch it up as needed.
» Power trunk release
» Repurposing idle-stop solenoid to be air conditioning idle compensating solenoid
» power window and /or power lock switches ?'s
Today at 7:44 pm by Joe73
Today at 7:41 pm by Joe73
» 1973 Chevelle SS 1 Family
Today at 3:45 pm by Limey SE
