lowering spring kit
Finn Monte
lowering spring kit
I'm looking for lowering springs that come from -75 Monte Carlo.
i have a new set of bilstein b6 shock absorbers so the springs have to fit with them.
if you can recommend something, then i will be happy to accept the tips.
Finn Monte- G3GM Member
Re: lowering spring kit
great stance in your car, what shocks it has?REVINKEVIN wrote:I have the Global West springs. I think the car has a good stance. They are not too low. I think it is about 2 inches front and rear.
i looked at the global west website but there were only front springs.
I installed Global West small block springs on my car, and it didn't lower it all all, especially the front. Â Mind you my car has no A/C and is pretty lightly optioned, so that might be part of the reason. Â I am probably going to cut half a coil and at some point to drop it a tad. Â I also use Bilstein shocks and like them very much. Â I would recommend them.
I found the Global west springs were a bit too soft on the front end, I'd prefer bit stiffer spring. Has anyone tried Moog 80090 Crown Victoria Police springs? Â They are short and have a 710 in/lbs rating. Â I think they might work well and they are cheap. The B-body guys use them
Here is my car with the global west springs front and rear:
76 Malibu- G3GM Member
fasrnur likes this post
Impalamonte has one of the nicest Montes in the country. I have a big block in my Laguna so the springs I have did lower it. 76 Malibu has a great point, look at the cop springs since his didn’t really lower his car that much.
- Street Cred : 19
A few years back I installed Belltech 2" lowering spring on my Laguna. Like the Global West springs for a small block V-8 they feel almost too soft. If I had a chance to do it again I'd order front springs for a big block. Better yet, I'd set my suspension up just like Revin Kevin did. The rear springs ride perfect.
- Street Cred : 34
moog springs i have a good experience. i put 72 le mans part front 5440 and rear cc501, they got a good stance in it.
The Monte Carlo Moog Website offers the numbers fron 590 and rear cc507, has anyone used these?
I want springs that are not too soft. rear height now looks like this, tires 235/75-15.
the following rings are 245/50-18, these are almost an inch smaller in diameter.
a small lowering would be necessary.
Those Moog 590s are stock replacement springs. They are only 400 lbs/in so they are on the softer side. They also will probably sit at close to stock height. You can cut the springs (tangential end only) to lower the front end, but its a trial and error process. If you cut too much they are junk. Cutting the springs also slightly increases the spring rate too.
The rear springs you listed are cargo coils, so they are variable rate as opposed to constant rate on the stock springs. They are probably a bit stiffer overall than stock springs, but should sit pretty close to stock height. Rear springs cannot be cut to shorten them.
i found these two companies that offer springs for these bodies.
does anyone have experience with these?
https://www.eatondetroitspring.com/db/es-partsinquiry2.php?
https://www.jamcosuspension.com/product/1973-77-monte-carlo-rear-coil-springs-rcs7377m
https://www.jamcosuspension.com/product/1973-77-monte-carlo-front-coil-springs-fcs7377m
Eaton Detroit spring is a good company. I haven't dealt with them directly, but know several who have and were satisfied. They are more expensive, but you can have them build springs to your spec, including higher spring rates and for a lower ride height. Since you want lowered springs, this might be a good solution.
I’ve got Moog 5375 rear springs. They sit close to stock height but feel firmer. On the front I’ve used Belltech 5148 springs with 2” drop spindles. KYB shocks all the way around. Ride is firm without being harsh and i like the stance.
TW Monte- G3GM Member
I ordered a Belltech 5839 1-inch lowering springs from ebay.
they go to Houston and from there by ship to Finland, it takes 2-3 months.
https://www.ebay.com/itm/Belltech-73-77-Chevy-Malibu-Monte-Carlo-Buick-Regal-1-F-1-R-Lowering-Springs/281167543768?_trkparms=ao%3D1%26asc%3D20140127102845%26meid%3D43eebd8340104ee39d4dddf10ff1c108%26pid%3D100148%26itm%3D281167543768%26pmt%3D0%26noa%3D1%26pg%3D2059210%26algv%3DOrganicCompBase%26brand%3DBelltech&_trksid=p2059210.c100148.m2813
Finn Monte wrote:I ordered a Belltech 5839 1-inch lowering springs from ebay.
I got a message, this order is cancelled.
is it normal to sell goods on Ebay that the seller does not have?
eBay has become such a scam. If you want I will get you some and ship them to you. I would guess that DHL ships to your country. You should make a list of what you need and I can put you together a care package and ship one big box.
- Street Cred : 19
the list of goods i need is long.REVINKEVIN wrote:eBay has become such a scam. If you want I will get you some and ship them to you. I would guess that DHL ships to your country. You should make a list of what you need and I can put you together a care package and ship one big box.
hothkis suspension i have a good experience,
I put a -74 Firebird TVs kit a few years ago.
can these camaro springs fit the front, the dimensions seem appropriate?
https://www.hotchkis.net/product/1970-1981-gm-f-body-front-sport-coil-springs-2-in-drop-small-block/
on the rear of these,
https://www.hotchkis.net/product/1967-1988-gm-a-g-body-rear-lowering-coil-springs-2-in-drop-2/
» DSE lowering springs - Thoughts?
» spring for A/C vents
Today at 12:36 am by Limey SE
