Rear coil spring help
G3GM :: Classifieds :: Wanted
I wanted to Upgrade the worn out rear coils and Had a set lined up but now the seller cant locate them, SO need some rear coil(s) or where to find Info at I know rockauto has the Cargo springs BUT in the description it says they are shorter than OE springs so that doesnt help me ANY SUGGESTIONS Text me 815-297-4437 Need to get these set up for Install by weekend
Re: Rear coil spring help
I didn’t get into springs on the 73-77 but just because it’s shorter isn’t really important. Spring rate is what matters. A taller low rate spring may compress under weight farther than a short high rate spring.
I installed Moog 5375 coil springs on the rear of my Monte a couple years ago. Sits at oem height and the ride is comfortable - not too firm, not soft/bouncy. (i know, sounds like Goldilocks…)
TW Monte- G3GM Member
» Coil Spring Spacers for Rear
» Rear End Coil Spring Perch/Mount - Different Designs
» Which Front Coil Spring?
