Rear End Coil Spring Perch/Mount - Different Designs
G3GM :: Classifieds :: Wanted
Today I stumbled across something I've never seen before when doing a rear end swap. When looking at the spring perch on the rear end I just removed from my 77 El Camino, it appeared to be a different shape and location from the one I'm installing on the vehicle. The replacement rear end came from a 74 El Camino. I've always assumed these housings where identical. Well that's not the case with this project. Here's a video showing both rear ends.
https://youtu.be/uAb2IXqIUfo
- Street Cred : 34
Re: Rear End Coil Spring Perch/Mount - Different Designs
The later one seems more robust. Maybe there was a problem with failures. Especially on an Elcamino with a load in it.
Any chance one is a chevy rear and the other is BOP ? Just a thought.
No, both are c-clip rear ends but that's and interesting question. I have a BOP rear end that uses the axle retainers on my 75 454 El Camino so I'll get some pics of it and see what it looks like.
- Street Cred : 34
I haven't seen that before. When I did my rear I noticed that one of the perches was a degree or 2 off from the other side. I went ahead and installed it and the spring is sitting fine and the ride height is the same side to side. If it was off I was going to cut it off and re-weld but it's fine.
Of course I did not notice it until after I blasted, clean, Prime & painted the rear. It's a BOP rear, the perch looks like your first pic.
I would think the perch in your second pic would have started to fold over from the weight.
73ss- G3GM Enthusiast
Looks like my 75 SS 454 El Camino with BOP rear end have the square spring perches like the 74 rear end. I have a 76 El Camino parts car that I'll check this weekend to see how its setup. I'm thinking the later rear ends have the round spring perches since GM tried to save weight and reduce production costs in the mid to late 70's.
- Street Cred : 34
- Street Cred : 34
Interesting... Might be a 77 only thing??? Hawk03, did you get your steering column installed?
- Street Cred : 34
Cool. Looks like this is exclusive to most or all 77 A-Body vehicles. I'm wondering if they did this for better suspension geometry? Or this was some cost cutting change in production?
- Street Cred : 34
I highly doubt a different style spring perch on the axle, that still lines up with the same pocket on the frame up top, would have any change to geometry. Geometry would be greatly effected with repositioning the upper and/or lower control arms or angles.
g3chevy wrote:Cool. Looks like this is exclusive to most or all 77 A-Body vehicles. I'm wondering if they did this for better suspension geometry? Or this was some cost cutting change in production?
Cost cutting 100%. This design change doesn't affect performance, and the miniscule amount of weight reduction per car translates into big savings on raw material cost.
Cost cutting makes perfect sense. But I'm still wondering why they would move the mount 1/2" further out from center than the original design? Could be so the brake line tucked under it nicely like the earlier version but using less material? Who knows. I've seen many different variations in designs from hoods, hood latch brackets, swivel bucket seat bases, fenders etc. so I guess this is just another one of those...
- Street Cred : 34
g3chevy wrote:Interesting... Might be a 77 only thing??? Hawk03, did you get your steering column installed?
Not yet, the weather turn cold quickly last year before I could paint the shaft and touch the column from where I scratched it trying to install it before. I bought a dash pad too and wanted to install everything (shaft, column and dash) at once but need to paint the dash pad. Its finally warming here so I can start painting everything.
Hawk03- G3GM Enthusiast
Winter just keeps lingering on this year. I've had the same issue with painting, but mine is because its been too wet or humid. We finally got a nice weather weekend so I'm hoping to get some stuff done as well. Keep me posted on the column install. Just want to make sure it works for your setup.
- Street Cred : 34
There is sometimes weird things you find on 2 identical cars. Small brackets thats changed or different designs on latches.Â
When i restored my chevelle 75 i actually bought 73 fenders thinking they where the same, however even if they look the same they fit like crap to the light buckets and the hood. Ive been having a tough time when i put the fenders on.Â
They lined up Nice to the doors since they Came from the same car ( rustfree California junkyard elcamino) so there is defenently difference in parts from year to year or plant to plant.
Hs1973- G3GM Enthusiast
I was given a 1975 Olds Cutlass rear axle and was told it has a posi - it does not, but I saved it from being scrapped! My plans are to rebuild it and gear it for my 1975 Laguna as I like the idea of eliminating the C-Clips. This thread made me take a closer look and the Olds axle has the heavier square spring mounts - I am like this axle more each day! I have the backing plates from a 1977 Monte Carlo with 11" drums that I will be putting on this axle so it will be a true Frankenstein axle when done!
Iggy- G3GM Member
