G3 diet plan for the street
G3GM :: G3 Tech :: Body
Page 1 of 4 1, 2, 3, 4  Next
Post by The Dude on Fri Jul 16, 2010 10:38 am
Well, it's no secret that we have land yachts. On the low side, I've heard of 3500lb factory cars all the way up to Bryan's 4200 lb 74 Malibu topping the heavier end. I'm gonna point out some of the ways that I have found to cut weight & some tips that have been posted here as well. These dieting tips aren't meant to strip your car down to a racer, but rather knock off the unwanted/unnecessary junk in your ride while still maintaining streetability.
Later models use steel inner fenders, whereas I have noticed that the 73's had plastic. Ugly as they were, this can cut a couple of pounds.
Suck those bumpers in! You want to lose some major lbs for free? There's close to 100 lbs of dead weight in there to be lost.
Some 77 models used aluminum drums. The aluminum drums can also be found on a wide variety of late 70 - early 80's vehicles for about 10 lbs of savings.
Bench seats & swivel buckets are heavy when compared to late model vehicles. Go junkyard hunting for some newer butt rests.
Ever notice how heavy your door is? Our cars have crash bars reportedly weighing between 80-90 lbs. Controversial as it may be to cut these out, they can save weight. *Still waiting for someone to do a write up on this one.
Factory steel wheels are heavy, especially you Cutlass guys & your rallies. They weigh a ton! A set of aluminum wheels, stock or aftermarket, will make a big difference.
Relocate the battery & switch to a drycell. This does 2 things for you. 1 - it relocates weight for better distribution & 2 - drycell's often weigh less than typical car batteries while also outperforming them. Nothing wrong with cleaning up the engine bay, right?
Fiberglass bumpers do exist for some of us as does trunks, doors, fenders, & of course hoods. Depending on how far you are willing to go, this could really add up in weight loss. Just remember that fiberglass doors aren't really a streetable thing since they require lexan glass most times (illegal in some parts of the country) & are inoperable so no more rolling them down to cruise.
Street Cred: 46
View user profile
Re: G3 diet plan for the street
Post by The Dude on Fri Jul 16, 2010 10:49 am
Here's some good tips from Corey (I made it easier to read & cut out some stuff that didn't really fit):
coreys73chevelle wrote:I removed all heater components, had no ac from factory, so my switch panel i made goes in the hole in the dash for the climate control was.
If you just start taking things apart the factory over does it with the bolts on a few things i have about 5 pounds of bolts i took off, quite a bit for small bolts. The dash is one that is over bolted in mine was at least.
also the big metal bar in the doors is 85 pounds (or so i was told by another g3 owner) that also will eliminate sagging doors
If you have no radio like me take out the speakers and ALL wiring for it, also the door buzzer and seat belt alarm wiring and that will also clean up the wiring.
Get lighter suspension parts of course like control arms, springs and a lighter transmission crossmember.
Trim is heavy when combined mainly the emblems and on the door sides and bottom chrome.
Get hood pins with locks so you can remove the pull system inside and the whole latch system under the hood.
Smooth out everything you paint by using a grinder like the frame. I took about 1/8" off my frame in the engine compartment after I cleaned it. It takes a long time but its smooth and shiny and the big chunks of steel are gone.
Jegs.com sells aluminum transmission tunnels for around $80 big weight difference.
The factory brake system is heavy too get lighter calipers and rotors,
Remove the factory insulation its cardboard and tons of crap insulation and get some Dynamat.
I'll keep looking for other posts to compile here, but feel free to add your ideas. I'd really like to keep this a streetable approach, so no lexan, gut the interior type of ideas.
Street Cred: 46
View user profile
Post by JB2wheeler on Fri Jul 16, 2010 11:06 am
Great subject! How could fiberglass hoods not be mentioned? I plan on putting a 2 inch cowl hood on my 74 as soon as I hit the lottery. If you REALLY want to lose weight, go to smaller and narrower wheels and tires. I have 17 inch aluminim wheels & tires with wide ones on the front as well as the back, they weight a ton. The 20 inch wheels I had on my Furd weighed a ton and I gave them away, tires and all. US Body makes the complete body, from bumper to bumper out of fiberglass but of course that does not qualify for this post. JB
Street Cred: 21
View user profile
Post by The Dude on Fri Jul 16, 2010 11:53 am
Rago wrote:Fiberglass bumpers do exist for some of us as does trunks, doors, fenders, & of course hoods. Depending on how far you are willing to go, this could really add up in weight loss. Just remember that fiberglass doors aren't really a streetable thing since they require lexan glass most times (illegal in some parts of the country) & are inoperable so no more rolling them down to cruise.
I mentioned the hoods in the first post, but it probably got lost in such a big article. Maybe I should break it down better?
Street Cred: 46
View user profile
Post by 74Malibu383 on Fri Jul 16, 2010 12:09 pm
To each their own on removing AC/Heater stuff. I’ll keep mine. I’m also all for getting rid of the inner bumper stuff, bench seat, steel wheels, lighter cross-member, stuff like that. However, I’m not sold on altering the body panels.
Food for thought - Let's say you go the fiberglass route, hood, fenders, trunk and bumpers. I'm not sure how much weight you'll cut out, but I'm sure it would be a ton. You would still retain all the factory glass, and it would still be streetable for all intents and purposes. However, what is all that fiberglass going to cost you? Going off of US Body Source, you're looking at $1,800 plus shipping. Not to mention we all know that stuff doesn't "bolt-on". So, add in the headaches, the fillers, the sandpaper etc. You have to be close to let's say $2,300 before you even get to paint. You put it all together, it looks amazing, and you shaved a ton of weight. Maybe even gained a half a second at the strip. Awesome……… However, it's still fiberglass. One fender bender and you're f'd. One actual accident, and you're totally f'd! There are some real idiots out there, and it’s just not realistic for a street car.
Now, let's take that $2,300 you just spent to make your car lighter and put it into the motor. You can order a deluxe (pan to carb) 350 crate motor w/290hp from GM for $2,500.00. That's a 100-150 more horsepower than the stock small-block had, and 60 more HP than the stock big block came with. Not to mention we all know you could build a much more powerful engine for a heck of a lot cheaper yourselves. This was purely an example.
You say you already have a pretty decent motor? Ok… still put that $2,300 into it and now you have a motor throwing down BIG power numbers while still maintaining a “streetable” car. Not to mention you’re probably gain more at the track with the added power than you ever would have with losing the weight.
- Just saying...
Street Cred: 20
View user profile
Post by The Dude on Fri Jul 16, 2010 12:31 pm
Good debating material! Smile Let's look at this from a different POV
74Malibu383 wrote:To each their own on removing AC/Heater stuff. I’ll keep mine. Nothing wrong with that. I just got rid of my AC stuff since I never used it anyways. I’m also all for getting rid of the inner bumper stuff, bench seat, steel wheels, lighter cross-member, stuff like that. However, I’m not sold on altering the body panels.
Food for thought - Let's say you go the fiberglass route, hood, fenders, trunk and bumpers. I'm not sure how much weight you'll cut out, but I'm sure it would be a ton. *Which means less drivetrain stress. You would still retain all the factory glass, and it would still be streetable for all intents and purposes. However, what is all that fiberglass going to cost you? Going off of US Body Source, you're looking at $1,800 plus shipping. Not to mention we all know that stuff doesn't "bolt-on". So, add in the headaches, the fillers, the sandpaper etc. You have to be close to let's say $2,300 before you even get to paint. That's chump change for you isn't it? LMAO You put it all together, it looks amazing, and you shaved a ton of weight. Maybe even gained a half a second at the strip. Awesome……… However, it's still fiberglass. One fender bender and you're f'd. Metal crinkles, fiberglass busts, either way it's getting replaced. One actual accident, and you're totally f'd! There are some real idiots out there, and it’s just not realistic for a street car. Again, the frame would save you, not the sheetmetal/fiberglass.
You say you already have a pretty decent motor? Ok… still put that $2,300 into it and now you have a motor throwing down BIG power numbers while still maintaining a “streetable” car. Not to mention you’re probably gain more at the track with the added power than you ever would have with losing the weight. Why not take it one step at a time & have both?
- Just saying...
Losing weight has more advantages than adding power such as quicker stopping, less drivetrain stress, & better gas mileage to name a few. I'm not a supporter of glass doors or really even bumpers on the street, but hood & fenders....... why not?
Street Cred: 46
View user profile
Post by 74Malibu383 on Fri Jul 16, 2010 1:06 pm
I personally can't stand hood pins (unless the car came with them), so I'm out on the hood. I know you can get a "bolt-on" one, but what's the weight savings on that? Is the weight savings worth the money? Regardless of whether you have it or not? Smile
Street Cred: 20
View user profile
Post by The Dude on Fri Jul 16, 2010 1:26 pm
Bolt on hoods require lighter springs, but retain the factory hinges. They still weigh a lot less than a steel hood.
According to VFN:
73-77 Flat Pin On Hood. Price=299.00 Weight=13
73-77 Stock flat Bolt On Hood. Price=399.00 Weight=18
73-77 2-inch Cowl Induction Pin On Hood. Price=305.00 Weight=13
73-77 2-inch Cowl Induction Bolt On Hood. Price=405.00 Weight=24
73-77 4-inch Cowl Induction Pin On Hood. Price=325.00 Weight=13
The heaviest hood is only 24lbs. How much does a G3 hood weigh? Something like 70 lbs right on your nose. Look how much weight you just dropped.
Street Cred: 46
View user profile
Post by 74Malibu383 on Fri Jul 16, 2010 1:40 pm
Are they finished on the bottom? Or are they rough like they were just pulled from a mold? I know I'm being a little picky, but I'd want it to look good too.
Street Cred: 20
View user profile
Post by The Dude on Fri Jul 16, 2010 1:46 pm
I know some of them look factory from the underneath. Not sure if they are all that way or not? Hopefully someone can chime in here, since I plan on buying one myself.
Street Cred: 46
View user profile
Post by 74Malibu383 on Fri Jul 16, 2010 1:58 pm
Well, if it does look factory underneath, then I would definitely consider it. 50lbs there, 100 in the bumper, hell, I might get under two tons yet!
Street Cred: 20
View user profile
Post by The Dude on Fri Jul 16, 2010 2:04 pm
If you decide to go ahead with the bumper tuck, take some pictures. I'm curious to see if it has the same mounts as 73 models or later models. Wondering when the changeover took place.
Street Cred: 46
View user profile
Post by 74Malibu383 on Fri Jul 16, 2010 2:09 pm
It's on my list. I'll probably end up cutting a couple inches off the width as well. I'll most likely end up welding up all new brackets and eliminating the shocks completely. If I ever get around to it, I'll take tons of pictures
Street Cred: 20
View user profile
Post by coreys73chevelle on Fri Jul 16, 2010 6:49 pm
or just order a fiberglass body shell if you have a chevelle! usbody.com has them for $3900 its the entire body.. hood, fenders, trunk lid, doors and yes the actual structure too! its under 1,000 pounds. just dont hit anything over likr 30 mph or your dead Shocked
coreys73chevelle
Street Cred: 8
View user profile
Post by TWBouska AKA Wooderson on Fri Jul 16, 2010 9:22 pm
anyone know how much a 74 chevelle/elco front end weighs? im trying to figure out how much weight ill save when i put on my 73 laguna nose here in a couple weeks...also, i second rago, if anyone tucks the bumpers, share some pics...id like to tuck the rear bumper on my el camino to smooth out the body along with the laguna nose.
Street Cred: 6
View user profile
