Wheel Size help?
Wheel Size help?
My car is a 74 Laguna and I have P275/60/R15 on the rear and P255/60/R15 on the front all currently mounted on stock 7" Rally Wheels.
Question is, what's the W I D E S T wheel I can use with these tires without having to tub the rearend or cut fender wells?
Also, what back spacing do I need?
Oidar- Donating Member
Re: Wheel Size help?
15x10 with a 5.5" backspacing should fit and tuck up nicely
BlackChevelleSS- Management
On the front too? Is that what you have? Any pictures?
you could get 8" on the front no problem... Those pics of the cragar SS's on the green malibu has the 275/60/15 tires on them but the backspacing is only 4" so it doesnt tuck up in the wheel wells.
THE 4.5" BACKSPACE WITH 10" WIDE AND 305 TIRE IS WHAT I AM RUNNING ON THE BACK AND THE FRONTS ARE 8" WIDE AND NOW HAVE 245/50 15 AS WELL NO RUBS AS FAR AS I CAN SEE
THE MALIGOON wrote:THE 4.5" BACKSPACE WITH 10" WIDE AND 305 TIRE IS WHAT I AM RUNNING ON THE BACK AND THE FRONTS ARE 8" WIDE AND NOW HAVE 245/50 15 AS WELL NO RUBS AS FAR AS I CAN SEE
What size were those slot mags in your early pics?
Do you still have them? Do you wanna part with 'em?
ALL READY PARTED WITH THEM THE BACKS WERE 10" AND THE FRONTS 7"
» 1973 Chevelle SS 1 Family
