Wheel size and backspace table from Weld Racing
Page 1 of 1 • Share •
Came over this PDF at Summit. It shows recommended backspace for a given wheel size:¨
Original document with several different cars: https://summitracing.custhelp.com/ci/fattach/get/99/1089836847
Fishgrinder- G3GM Member
- Street Cred: 0
Re: Wheel size and backspace table from Weld Racing
Thanks for the info. I printed it out. JB
- Street Cred: 21
any idea, the recommended backspacing on 15 x 10?
alleyball4- G3GM Member
- Street Cred: 0
5.25" - 5.5" Is what most recommend. Limey is the self proclaimed 10" king so he might know if I'm off.
- Street Cred: 48
My 10" rims have 4" backspace. I have to have the stinkbug stance to keep the tires from rubbing or getting cut by the wheelwell lip. 295/50 tires.
I will get another set sometime that will have at least 5.25" b/s. I'm thinking that 325's would be ok on a 10" rim with 5.5" b/s. At that tire size, the most you should have to do is roll the wheelwell lip.
bigredlaguna- G3GM Enthusiast
- Street Cred: 31
alleyball4 wrote:any idea, the recommended backspacing on 15 x 10?
FOR THE 73 - 77 15 X 10 WHEELS YOU WILL NEED A 4.5" TO A 5.5" backspace depending on the wheel maker my self will be going to a 5.5" Backspace for my rears
- Street Cred: 60
Similar topics» PCD WHEEL CHART
» Oris BC3 Air Racing Limited Edition
» racing boy lining rim sticker rm30
» BC Racing Coilover Height Adjustments
» FS Momo Mod 88 Steering Wheel and adaptor.
» ~~Introduce Yourself~~
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
