window alignment
window alignment
On my 73 the window dosent roll up straight. The rollers are all there and once the window is up it seals up but when its say halfway down its crooked towards the front. Seems the regulator has some play in it,is there a way to adjust or fix it or do I need a new regulator?
Re: window alignment
I had that happen on my 99 monte and on my dodge. Take a peek inside the panel, chances are it may have gotten loose from one of the attachment points (don't know what they're called). When it gets to a certain point they catch up to the glass usually about 3/4 of the way up.
BTW, if you ever wanna sell that 73, let me know
Remove the door panel, and get a good look and inspection of the window regulator and the adjustable stops for the window. You may detect the problem that way, if it's just got a simple adjustment problem. It takes some time to get the regulator and stops tweaked just right.
If you can locate a Fisher body service manual there are step by step instructions on how to adjust window glass. But if it just went crooked then i would look for something loose or broken as motioned above.
77mali wrote:BTW, if you ever wanna sell that 73, let me know
no no no
i need it to go with my 454 bucket seat 73.
Take it easy fellas! Thanks! Not selling, at least not now,if I croak I will leave instructions with the misses to contact one of you. The regulator arm on the front of the window seems to not be holding the window properly I dont think there is anyway to fix that aside from replacing the regulator.
are all 4 bolts still holding the reg on?
1973montec- Donating Member
LOL
That stinks! I have a 77 Body manual if it will help you I can look it up & post a pic. Let me know.
77mali wrote:LOL
help, thats what he wants............. get crackin and find some answers.....
Yes they are all there. I gotta do some more investigating.
1973montec wrote:77mali wrote:LOL
I'll wait for his reply. I'm being a real lazy @$$ today.
Is that a body book on your bench seat? I just noticed
window alignment
Ant,
I have the 1973 Fisher body manual and can copy and post the page(s) you need. Since they refer to body numbers instead of models in the book I'll need the first 4 numbers of your VIN. For example my Chevelle is 1A37.
Lovett- Donating Member
77mali wrote:Is that a body book on your bench seat? I just noticed
That is. Thanks Lovett. I very much appreciate the effort)
» Roof rail /Window alignment
» Quarter window/Opera window trim removal
» stock suspension alignment specs
