carpet
texan01
alleyball4
carpet
I finally have the carpet in stalled in my Elco project. I kinda forgot how much work it is the get it fitted and trimmed. The hood release cable has to get fished through the left kick panel of course, and the grommet it the firewall is almost impossible to get to after the cable is through the hole. Good thing I'm stubborn as hell or it wouldn't get done.
So the interior is close to being done. Still have to screw the sun visors in place. The new sill/scuff plates are a problem. NPD shipped two R/H plates instead of a R & L....so those have to go back in order for NPD to ship a correct pair.
I want to put a smoke tint on the back window yet. Haven't ever done that before.
Re: carpet
Well it's about time...I've been waiting like 6 months for you to post a picture burning rubber. (I'm one to talk, right?)
Re: carpet
Don't hold your breath waiting for a burn out !! This project is quite a way from being finished !
There's a local car show scheduled near here, a small one in a small town, in Coleman Michigan. Anyway, it's on June 7th & 8th. Two guys from the Elco forum will be there, but my Elco sure wont be done by that time, so I'll take my '74 Malibu instead.
I don't plan on any burn outs with that one though. The idea of having 255s on the rear was for traction without noise !
Re: carpet
My car won't be "Finished" then either but I'm at least hoping that the darn thing will be able to at least be driven around in or at the very least be able to move around on the homestead.
You're way ahead of me! LOL
Re: carpet
Maybe not....! I have to buy about 400 bucks worth of paint & supplies yet !! And then 5 new tires, two stainless steel mufflers, stainless tail pipes, and.....well, you know
At least the interior is almost together......
Re: carpet
I just installed the sun visors finally. I wasn't exactly sure where to punch through the new headliner without messing it up, so I took a couple pictures of where they are located in the Malibu, and found the correct location.
My next move is the weather strips on the doors & roof rail, and the outer window felts. Luckily I bought pairs of GM NOS inner & outer window felts some years back.
I still need a dash cap. I have one in the Malibu, which turned out quite good.
Here's the dash on the Malibu which is the same color etc.......
I have the little triple gauges where the OEM clock used to be, same way in the El Camino.
Re: carpet
Are those Stewart Warner gauges? They look right at home there.
I got a dash cap before I started restoring the dash pad in another manner. It really was terrible- the fit & finish of yours looks very good- do you remember where you got it? There are so many on the market it's hard to find a good quality one from the pics most vendors post of them. Mine was from Just Dashes...it was Just Awful! With inbound shipping costs- I might as well have tossed the $125.00 in my fireplace.
Re: carpet
I did the same thing with my gauges except since i have a non a/c car I put them where the drivers side a/c went would be. There was a stupid little storage compartment there that always looked out of place. I do have to give props, pila i thought mine looked good, yours looks awesome.
Re: carpet
The little triple gauge panel is nothing special. I've been using them for years, where there's not much space or panel room for gauges. They are available at Advance auto, in black face or white face, for under 40 bucks.
This one has an ammeter, which is not easy to hook up, because of the #10 wire required, when tapping into the main feed wire from the starter. But the Elco project has a volt meter instead of an ammeter, which is easy to hook up of course.
Re: carpet
pila wrote:The little triple gauge panel is nothing special. I've been using them for years, where there's not much space or panel room for gauges. They are available at Advance auto, in black face or white face, for under 40 bucks.
They looked like SW from a distance, lol. They make small ones too (a bit more money) but they have styles available that are reminiscent of the G3 cars.
Re: carpet
Stewart Warner is sort of top of the line parts, and have been for nearly a century. I used a few Stewart Warner gauges in the last airplane I restored, and getting them approved by the FAA was not a problem, since they are OEM on some older airplanes. Approval is the name of the game in aviation, and that's why things are so expensive.
Re: carpet
They really have some nice stuff. Maybe for a future build for me. If i can get through this one first.
Re: carpet
The little gauges are mounted on a panel that is the same size as the factory clock face panel, so it's reasonably easy to do, except maybe putting the holes in for the gauges. I use a fly-cutter in the drill press for holes up to over 3 inches. And a decent fly cutter is available ay Sears, and it's adjustable for diameter. The gauge panel :
front:
I used aluminum sheet stock for the plate, since I have lots of it around.
front:
Re: carpet
Of course, it's what's up front that counts !!
507 cubic inches of Caddy
Re: carpet
Bill I'm sorry to sound presumptuous (not my intent at all)
You have such a nice build there- why don't you start your own thread under project pictures in the forum & have all this good stuff in one place?
We're all diggin that Camino.
Re: carpet
Ok Pila, did you have to notch the frame for clearance? We installed a 500 in a 78 Impala and had some clearance issues.
Looking great!
Looking great!
texan01- G3GM Member
Re: carpet
Hi Texan. No, I didn't notch the frame. It's close clearance to the front suspension though. No room for headers. Not a problem for what I want though, which is a daily driver, with the hassle of headers. Thanks for the kind words !
77Mali, do you mean just a thread on the project ? I could do that OK. I have a project thread on the El Camino forum, that I started in 2009 !! That thread has 24,563 views now.
Bill
Bill
Re: carpet
Post a link to that then. I'd like to check the forum out too. Thanks.
Re: carpet
OK.....
http://www.elcaminocentral.com/
My user name there is steelybill by the way...
Here's the photobucket link. I don't have as many pics of the Elco project as I did before though.
http://s561.beta.photobucket.com/user/steelybill/library/El%20Camino%20Restoration
Here's the Malibu link too
http://s561.beta.photobucket.com/user/steelybill/library/Malibu
Re: carpet
I forgot to mention that I installed the driver's side roof-rail weatherstrip today, but got too cold to do the other side. Maybe tomorrow...
Re: carpet
Hey, I have the same cup holder thing on the floor in my Laguna! Really though, you do some nice work Bill!
Pontichev327- G3GM Enthusiast
Re: carpet
Thanks !
Today I installed the right side roof rail weather strip, and the door window felts on the top edge of the doors. Now I have to fool around with the window adjustments. Not my favorite job for sure, but I hate noisy/ leaky windows !
Re: carpet
Well, NPD did it to me again. I had to ship the door sill scuff plates back, since the box had two R/H plates in it.
Today the "replacement ' box arrived, and it had the same parts the I just shipped back !!
I told them to just credit my card & I'll get a pair someplace else.
Today at 1:56 pm by REVINKEVIN / Mr. 600+HP
Today at 12:20 pm by g3chevy / Mr Pontiac
Yesterday at 4:38 pm by Mcarlo77
» Dash Solutions
Yesterday at 3:22 pm by 76 Malibu
» Window louvers
