what size rear end gears came stock in a 75 monte
has a 350 and came with a 4 bbl from the factory, probably a 350 trans
alive 75- G3GM Member
Re: what size rear end gears came stock in a 75 monte
Diameter? Probably 7.5" Ratio? Matters what options were put in or ordered.
Check your code numbers to cross reference them. There's a bunch of info on here through the home page under Chevy. The code is stamped on the axle, passengers side between the brake hub & the axle housing, on the side that faces to the front of the car, usually.
8.5 rear its probably a 2.73 but could even lower.
I don't believe the 7.5 was used until the '78 models, G bodies etc The 8.5 will take a lot of punishment, from a small block, at least mine have.
I think some '77's had 7.5's.
My 77 has a 2.56 ick ick
2.56 those sound like salt flats gears.Limey wrote:My 77 has a 2.56 ick ick
My '77 Malibu has a 8.5" with 2.56:1 gears. salt flats is right.
Dinomyte- Donating Member
Most seem to come with 3.08 or 2.73. Spin the tire by hand and count the rotations of the driveshaft compared to the tire.
Pontichev327- G3GM Enthusiast
yeah i was thinking about counting the rotation of the drive-shaft, thanks for the info
» Monte Carlo rear window????
» Max tire size for 73 Monte Carlo
» Was rear ended in the Monte today...
Today at 12:36 am by Limey SE
