Roadcaptain's 77 Build Thread.
+13
michiganlarry
17 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Roadcaptain's 77 Build Thread.
Roadcaptain S3 wrote:
The mats came from Auto Custom Carpets (ACC). They were the ONLY comapny I could find that had the right color and the "Malibu Classic" embroidery.
COOL mats!
Love the color combo.
Cort www.oldcarsstronghearts.com
"Everybody wants love to be easy" __ Nitty Gritty Dirt Band __ 'Stand A Little Rain'
Thanks Cort.
I was gonna go for black embroidery, but I kinda like the subtle look a little better.
YW!
Hmmm ... I agree about the subtle look for the embroidery. I think the black would've stood out a bit too much, if that makes sense. However ... a light-dark brown might've been an interesting choice.
"I know there's so much more to life" __ Vonda Shepard __ 'Searchin' My Soul (Ally McBeal)'
hey captain, thanks to your instructions i got an almost new center console lol. i sadly never remember to take before photos. but it was the stock maroon and badly beaten up. 100% improvement.
wunderlich_33- G3GM Member
Seat belt Solution...at last!
The swivels were in and the mounting points did not work for factory swivel belts that I paid $$$ for. #*#!
Heres with the drivers seat all the way forward...note the star bolt for the seat belt base. When the seat was all the way back (like it has to be to fit my fat butt) the seat trim piece and slide rails covered the bolt. Obviously, the stock swivel belt base stopped the seat from going back far enough.
I searched and read, couldn't find too much about belts anywhere.So then I posted here whining about it. Wally (bless him) said he used some Camaro belts in his ride. I poked around a bit and came up with some from a 93 Z28. Even got the right color. I THINK any belts from a 93-02 Camaro or Firebird will work, but not 100% on that. These mostly were plug and play.
This is next to the factory bench belt (chevelle top, Z28 bottom). Note that the Z28 belt does NOT have a retractor on the bottom end, just a steel plate with plastic sleeve. That's kinda important for seat clearance.
Note the roof retractors are ALMOST identical...more on that in a minute..Chevelle-red,Camaro-black
The retractor bolted right up to the roof, BUT the cover wouldn't allow the belt to slide in and out. I had to trim the cover just a little bit to allow for proper install. You can see it here:
The floor mount bolted right in, as did the female side of the belt. I was even able to leave the sleeve intact since it bent enough to allow the seat to slide back.
Seat forward:
Seat all the way back:
So there it is, problem solved...nearly drove me bat****. If you want to update your belts to something a little newer, or if you've swapped out the bench or if you just want that damn stock retractor out of the middle of the floor, look for 93-02 Camaro or firebird belts.
Now I have to figure out how to get some guides on without tearing up the seats...Wally?
Seat forward:
Last edited by Roadcaptain S3 on Wed Apr 15, 2015 6:16 pm; edited 4 times in total
Thank you sir...not perfect, but much better than nothing.
I hated that factory retractor in the middle of the back floor.
That came out really nice! Good work!
calm down buddy. gm uses the same hole for the bracket that holds the back leg of the swivel. than they put another hole for the seat belt. please see pics
driver side- left bolt would be stock location for a bench seat retractor. right bolt is factory location for bucket seat retractor
seat is all the way forword
seat is all the way back
1973montec- Donating Member
Thanks.
Hmmm. Maybe different for 77 or a bench seat car?
My car doesn't have the right hand hole.
Either way, kinda like the camaro belts better. Cheaper too.
its good to know about the Camaro belts.
I know a guy building one hell of a 75 laguna and he says where he lives hes not allowed to have anything other then a stock belt in the car so hes been trying to find one for about 2 years now. I think the camaro ones would pass inspection though.
hes just not allowed after market safety equipment.
good job though. its nice when you get another piece of the puzzle
tain/>
[color=#cc00ff]Now I have to figure out how to get some guides on without tearing up the seats...Wally?[/quote]
That's a hard one as its Vinyl. When I do Upholstery I put the screws in the seat before the cover goes on then push down on cover to find the screws and mack a small "x" with a razor blade and back them out. Not sure who did your covers but feel around by pushing with your thumb and see if you can feel a screw head. If its a fabric seat you can use a pin and push in to find the hole. You may have to do that on the vinyl to find the hole.
I need two of the retainers in black. I have the piece that bolts to the seat. I think some one sells new ones now days.
I've poked around on the vinyl and can't feel anything in the normal area to mount to. I THINK these seats may be from a 73 without the shoulder belt. I can feel the upper edge of the seat and may try mounting them there.
As it is, the shoulder belts cuts across high and at a weird angle like you can see in the pic.
I might have some retainers...I'll check the pile and pm you.
Do a Google image search for the seats to see the location for them in general they are down the side a bit.
I actually have another set of swivels in my basement, but the car is at my buddies place getting the shifter and column installed.
I still have to get the passenger side belt in as well. Once those two thing are done, I'll work on getting the belts guides in place.
I ran into a problem with the column swap, long story but if anyone wants to swap columns, do the best you can to obtain a column from the same year as the car you have.
I'm going from a 77 Â non-tilt /column shift to a tilt /floor shift column
I have had to combine parts from two different columns, one from a 7? Â Chevelle or Monte, and one from a 77 Gran Prix. The turn signal switches, steering wheel, horn switch and some of the column guts have to line up properly and all of that seems to differ from year to year depending...I'm still piecing things together and will report on specific trubbas when I'm done...should have it finished Monday.
I knew going in that the 73 and 77 columns differed from the 74-76 on the bottom end and with the wiring. What I didn't know was that the 77 also differs from the other on the top end as well. I'm getting it worked out, but it's been more complicated than just swapping it in.
» 1974 chevelle build thread
» The interchangability thread
» repro wheels that can be fitted wth OEM hubcaps
Page 3 of 4
Sat May 18, 2024 1:56 pm by REVINKEVIN / Mr. 600+HP
Sat May 18, 2024 12:20 pm by g3chevy / Mr Pontiac
Fri May 17, 2024 4:38 pm by Mcarlo77
» Dash Solutions
Fri May 17, 2024 3:22 pm by 76 Malibu
» Window louvers
