4.56 Ring/Pinion Ratio with a SB350/TH350
+6
alowerlevel
Oldschool454
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 4.56 Ring/Pinion Ratio with a SB350/TH350
It's kind of hard to tell for sure but the wear looks a bit uneven in the pics. How does it feel when you rotate it? I would measure each w/ the indicator as you rotate the hub just to verify. You might have to modify the shimming.
Are you sure the preload isn't supposed to be 16-18 in/ lbs.
The manufacturer of the bearing kit (Yukon) states 14-19 for new bearings and 6-8 for old bearings. I have old dummy slip-on bearings that i'm using for set up.
Oh I see. I thought you put the new bearings on at 6-8. Gotcha.
Page 2 of 2 • 1, 2
Page 2 of 2
